Does Honda (or aftermarket) make a seal/ gasket kit that comes with all the rebuild stuff??
What I'm looking for is a company that makes a kit that you can buy that has all of the gaskets and seals for a rebuild on an H22A. I would need IM/exhaust man. gaskets, oil pan, head, valve seals, cam seals, valve cover, and all the little rubber seals and gaskets...Thanks
Are there any aftermarket kits that anyone recommends? I just checked Hondaautomotiveparts.com . So I would need #1 and #2 here?
http://www.hondaautomotiveparts.com/...SMISSION+ASSY.
All the seals as in the valve seals too? Oil Pan?
For my H22a the block kit was like $40 and the head gasket kit was like $160
On honda automotive parts, the headgasket kit is $202.51 and the block gaskets are $51.01. Does this sound right to you? Where did you get yours?
when you buy this 50 dollar bottom end gasket set
does it include
ALL GASKETS?
my engine is torn down to bare block, needing to be rebuilt.
does it include
ALL GASKETS?
should have all normal o-rings and seals that need to be replaced as per the helms manual. It may be missing a few odds and in's.
look, you want a rebuild kit? or a re-gasket kit....get a full gasket kit, it comes with every seal, every gasket and every o-ring on the car...valve seals, head gaskt, IM, EX mani< tb gasket, all of that
itr1235
Apr 11, 2007 08:02 PM
prostreetonline
Nov 9, 2005 09:05 AM
2000CX
Jun 11, 2003 07:20 AM
