need sum expertise please...
Old Apr 2, 2003 | 08:37 AM
sailor's Avatar
Default need sum expertise please...
car starts, but just doesnt turnover, ive performed tests on the ignitor, and coil , and also swapped distributors, everything is good in that aspect. where should i check next? relay? where is the main relay located on the 97accord lx 2.2no tec?
thanks,
j
Old Apr 2, 2003 | 08:49 AM
Spade's Avatar
Default Re: need sum expertise please... (sailor)
Turnover happens before a Car can start.
please be more clear.
Old Apr 2, 2003 | 08:52 AM
sailor2's Avatar
Default Re: need sum expertise please... (Spade)
it cranks but doesnt start, sorry.
Old Apr 2, 2003 | 10:05 PM
aeolus's Avatar
Default Re: need sum expertise please... (sailor2)
i would say timing.Check yourtiming belt.
Old Apr 2, 2003 | 10:55 PM
speedaccordinly24's Avatar
Default Re: need sum expertise please... (aeolus)
how do you check the timin belt? the belt is brand new by the way
Old Apr 4, 2003 | 04:21 PM
aeolus's Avatar
Default Re: need sum expertise please... (speedaccordinly24)
line up the timing tdc line through the flywheel peep hole and the cam gears and make sure all the timing marks are right.
patm95
Honda Civic (2001 - 2005)
Oct 4, 2013 06:29 AM
Dancing is Forbidden
Aug 27, 2005 11:47 PM
hondanamics
Sep 20, 2004 06:17 PM
tangb2023
Jul 9, 2003 09:17 PM
