Replacing Thermostat
Old Apr 2, 2003 | 08:36 AM
KEVlN's Avatar
New User
Default Replacing Thermostat
Since the search function is not working properly I am having trouble finding answers to my questions. I'm replacing a thermostat in an integra today. Can anyone please explain the install for me. Thanks. I have never done this before, but I am learning how do all this on my own, so any help would be great. Pictures help too. Thanks.
-Kev
Old Apr 2, 2003 | 09:07 AM
IN VTEC's Avatar
Default Re: Replacing Thermostat (B8TeenRex)
Clear a path to work.
Remove the ground strap and disconnect the fan thermoswitch connector.
Remove a couple of 10mm bolts and crack open the housing.
When you install the new thermostat, make sure the alignment pin faces in teh correct orientation.
Old Apr 2, 2003 | 09:15 AM
NeoGSR's Avatar
Default Re: Replacing Thermostat (IN VTEC)
that's about it, just make sure that the surfaces are clean and the alignment pin is facing the right way
Old Apr 2, 2003 | 09:23 AM
KEVlN's Avatar
New User
Default Re: Replacing Thermostat (NeoGSR)
thanks
Old Apr 2, 2003 | 09:49 AM
Eva01's Avatar
Here you go: DIY Thermostat Replacement
Old Apr 2, 2003 | 09:56 AM
Toda Built's Avatar
Default Re: Replacing Thermostat (Eva01)
also make sure you use a brand new seal ring!!
Old Apr 2, 2003 | 10:01 AM
KEVlN's Avatar
New User
Default Re: Replacing Thermostat (SH_LUDER)
You guys are so quick. That's why I honda-tech. Thanks.
-kev
Old Apr 2, 2003 | 10:28 AM
Rory Breaker's Avatar
http://www.bseries.net/html/garage/thermo.php
I just pop off the housing, swap the thermostats, pop it back on, bleed the lines and go to town
Old Apr 2, 2003 | 10:48 AM
KEVlN's Avatar
New User
Default Re: Replacing Thermostat (newgsrdriver)
Great instructions.
EDIT-where you at the ITR expo last year? I was there with a friend of mine.
[Modified by B8TeenRex, 1:49 PM 4/2/2003]
Old Apr 2, 2003 | 01:17 PM
That isnt my site...its Trey's (Asahi on HT). I believe he was at the expo, although I dont remember for sure.
Old Apr 2, 2003 | 01:56 PM
sonicblueteg2k's Avatar
i replaced my stock thermostat with a mugen, i dont think it really did anything
Old Apr 2, 2003 | 03:56 PM
IN VTEC's Avatar
Default Re: Replacing Thermostat (sonicblueteg2k)
It probably won't show on the ECT gauge until you add water wetter.
vinuneuro
Sep 10, 2013 05:56 PM
PinoyDelS0l
Feb 2, 2009 05:40 PM
EF7
Apr 22, 2008 04:41 PM
r33dm0n3y
Oct 25, 2007 09:18 AM
DomDomBoy
Nov 19, 2001 07:43 AM
