lsvtec or crvtec????
Old Apr 2, 2003 | 04:30 AM
2slo4me's Avatar
Default lsvtec or crvtec????
hey guys im building a motor but i dont know what i should do some opinions please should i go gsr lsvtec of crvtec ????? thanks let me know some 1/4 mile times and what head is best to go wit a gsr head an si head or type r head??? thanks again
Old Apr 2, 2003 | 06:52 AM
1hottEG6's Avatar
Default Re: lsvtec or crvtec???? (spider69911)
I cant speak for an ls/vtec, but i can for a b20. I had a stock b20 with b16 head. All stock ran really really well. I used to have a type r, was more powerful than at low end, however with the b16 head, didnt get as much lift as the ITR. But ls/vtec 1.8, b20 2.0. MORE displacement more power.
Everyone is going to be bias towards which they like: just my .02. Just get as much info from people, look at dynos etc... all depends what u want out of the setup.
Old Apr 2, 2003 | 07:12 AM
LudeToAHatch's Avatar
Well, if you're building the motor and plan on resleeving it anyway, just buy the LS since it's much cheaper and bore it out to 84mm. This will give you the same displacement as a B20/vtec. The B20 and LS both use the same crank which gives them the same stroke (89mm). The only difference between the two is the bore... 81mm for the LS and 84mm for the B20B/Z.
Old Apr 2, 2003 | 07:35 AM
2slo4me's Avatar
Default Re: lsvtec or crvtec???? (LudeToAHatch)
thanks for the info guys so from my understanding the difference is the piston size does anyone know if the ls or 2.0 comes fully forged or semi?? thanks again
Old Apr 2, 2003 | 09:13 AM
irev210's Avatar
id go crvtec cause thats what i have.
Hes right though, people are gunna be bias as to what they have.
Honda cranks are forged, their pistons arnt.
Old Apr 2, 2003 | 10:25 AM
I didn't notice you included gsr into the mix... If you're going to "build" a motor, I would recomend the gsr. You can get just as much power out of that engine as you can from a ls/crvtec, and it's more reliable. for a Frankenstein engine, it's more than just slappnig a vtec head on and expecting alot of power. There's many other factors.
When you say you're "building a motor", what exactly do you plan to do? Is this for Turbo or N/A? How much money do you have to play with?
I guess I'm biassed towards the GSR because I have one
[Modified by LudeToAHatch, 7:27 PM 4/2/2003]
Old Apr 3, 2003 | 03:05 AM
2slo4me's Avatar
i have about 2500 to 3000 to play with im juicing the motor yay for NOS well so far im thinking of going ls vtec cause it seems like a stronger block but out here in nyc ive seen some fast crvtec cars running but do i have to resleeve that motor??? thanks guys
Old Apr 3, 2003 | 07:01 AM
You don't "have" to resleeve the crv block if you're going all motor, but it's safer because the stock crv sleeves arn't made for high compression pistons. But, since you plan on squeezing, I say yes you should sleeve the block. The crv sleeves are weaker than the LS sleeves stock. I know a guy boosting up to 16psi on stock LS sleeves.
In your case, I would say stick with LS/Vtec since you don't have much money to play with. The Crv/vtec build will cost you around 5000. With the LS, you can "half ***" it a little more. However, if you do go with the LS, I would at least get some good pistons and rods...ie. ITR, CTR.
Old Apr 30, 2003 | 05:50 PM
rota426's Avatar
^A crvtec does not have to cost 5k, in fact, not nearly that. Engine:800-900 shipped, b16 head: 400-500 shipped, so you leave it stock all over, and maybe you have the tranny from your old b-series. Thats good for 150whp and about 135wtq, at only 1400. Throw in an extra 500 for anything that goes wrong, and seals, mounts, whatever. Only 1900. Lots of potential, no costly boring and sleeving, run low psi if you turbo until you have the money to build the bottom end/block to a CRVTEC MONSTER!
Nate
Old Apr 30, 2003 | 06:27 PM
warwagon's Avatar
Default Re: lsvtec or crvtec???? (styler7)
please spare yourself and don't boost a crv block or spray one!!!! i've seen the cracks and they are beautiful
Old Apr 30, 2003 | 09:38 PM
MikeMAN's Avatar
Default Re: lsvtec or crvtec???? (warwagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon &raquo;</TD></TR><TR><TD CLASS="quote">please spare yourself and don't boost a crv block or spray one!!!! i've seen the cracks and they are beautiful </TD></TR></TABLE>
sounds like u dont' have much experience with b20's. everyone knows the sleeves are weaker, but they ARE NOT glass..
i wouldn't hesitate to run a 75shot on my motor right now
mike
low&slowef
Mar 5, 2011 03:02 PM
Sr420Det
Nov 10, 2010 07:49 AM
srt dub-R
Nov 6, 2007 10:51 AM
hspoon
Apr 4, 2007 10:14 AM
Damills
Jan 26, 2007 01:02 AM
