timing belt and water pump install, how much?
Old Apr 1, 2003 | 09:32 PM
SRd240sx's Avatar
Default timing belt and water pump install, how much?
How much plus parts and labor? I have no motor experience so I don't want to touch it. Lemme know! BTW anyone wanna help me out?
Old Apr 8, 2003 | 01:29 PM
SOHC_MShue's Avatar
Default Re: timing belt and water pump install, how much? (98civichb)
don't go to the dealer. If you do it is around 400-500 i think. I bought a whole timing belt package from inlinefour.com for around 160 and i am about to get a friend to install it for probably around 125
Old Apr 5, 2004 | 11:25 AM
92nb's Avatar
I recommend talking to the parts dept. at Honda and get a list of the parts needed for the job. Once you've done that, go to hondaautomotiveparts.com and enter the part numbers in. Their prices are unbeatable.
Benefit: You get the exact parts that the dealer would use for a fraction of the cost.
Installation: I would pay a friend whose done this many times before or has personal exp. with your motor in particular.
Cost: $270 Parts and Installation. Dealer cost: $600-700.
Hope that helps, Good Luck!!
Old Apr 5, 2004 | 12:35 PM
SleepyEG's Avatar
Default Re: timing belt and water pump install, how much? (92nb)
MAKE SURE you get Honda OEM fasteners for the crank pulley bolt. If you try to reuse the old ones, you are looking at a lot of frustration and stuff braking. The old bolt cannot be re-used. Make sure to follow the manual specs to torque that bolt back in.
Just trying to save frustration.
~James
Daisysi
Southeast
Jan 8, 2008 06:57 PM
2ndName
Dec 17, 2005 06:08 PM
abeaujuin
Jul 29, 2004 06:47 AM
ShiftDown
Jul 21, 2002 03:01 PM
SleepinGSR
May 17, 2002 11:24 PM
