Is mobil 1 tranny fluid any good?
Old Apr 1, 2003 | 06:17 PM
Buckshot's Avatar
Default Is mobil 1 tranny fluid any good?
anyone ever use it?
how much better is mtf?
also do you need to add anything to the fluid for the lsd
Old Apr 1, 2003 | 06:35 PM
black2001gsr's Avatar
Default Re: Is mobil 1 tranny fluid any good? (Buckshot)
I use it and its great.
Old Apr 1, 2003 | 07:42 PM
ejprimo's Avatar
Default Re: Is mobil 1 tranny fluid any good? (black2001gsr)
mobil 1 is a GL-5 spec. transmission fluid whereas your honda transmisson calls for a GL-4 spec. transmission fluid.
Old Apr 1, 2003 | 08:56 PM
SurferX's Avatar
Default Re: Is mobil 1 tranny fluid any good? (ejprimo)
I remember Mobile 1's disclaimer on their gear oil saying it should not be used in transmissions that can use motor oil like our trannies. A couple years ago before the Honda MTF, Honda recommended motor oil.
Old Apr 1, 2003 | 09:15 PM
98type_r's Avatar
New User
Default Re: Is mobil 1 tranny fluid any good? (SurferX)
i was wondering the same thing, was gonna do a fluid flush on the weekend. The guy at the parts store said to stick w/oem Honda fluid.
Old Apr 1, 2003 | 10:14 PM
Buckshot's Avatar
Default Re: Is mobil 1 tranny fluid any good? (tie par)
how much is the honda fluid?
Old Apr 1, 2003 | 10:26 PM
98itR484's Avatar
~$3 a quart, (yes i know prices will vary) well worth it
Edit: for a ITR you need to buy 3 quarts, you'll only use 2 and some change
[Modified by 98itR484, 11:27 PM 4/1/2003]
Old Apr 1, 2003 | 10:43 PM
mikehonda's Avatar
Honda recommends Honda MTF. Synthetic is formulated for the engine, not the transmission!
Old Apr 5, 2003 | 11:20 AM
Niemi's Avatar
Why play games? Just use Honda MTF!!!!! I tried a synthetic, got 5th gear synchro grind. Drained and replaced with Honda MTF, the grind is completely gone, use 3 quarts.
CRP
Nov 5, 2017 01:06 PM
PerryRT
Nov 24, 2008 01:46 PM
wastedyouth2542
Jul 16, 2008 05:22 AM
mika
19
Oct 4, 2004 12:45 PM
EK45VTi
30
Jun 5, 2003 05:49 PM
