Stock Radio Wire Diagram
Please help with this.
I need some wire diagrams showing which color is for what speaker, ground, acc and so on.
I tried to search with no results
the diagram is on the factory radio in most cases.
otherwise you can find an inexpensive voltmeter at any radio shack for 15-20 bucks.
you can also use a small battery AA or 9V to test for the speakers. they'll all be on the same side of the plug in a group of 8. make the connection between two wire and if its a circuit the speaker will make a pop noise.
sorry I can't just hand the info to you.
For your install questions when it comes to hu always checkout this site i discovered called installdr.com
go to this link it has the info you need.
http://www.installdr.com/Harnesses/HA-Wiring.pdf
6KAOS6
26
Feb 19, 2011 07:22 PM
crxmex
Sep 17, 2006 10:37 PM
