Headgasket reuseable ?
Old Apr 1, 2003 | 03:48 PM
zilverz's Avatar
Default Headgasket reuseable ?
Honda OEM headgasket reuseable if the motor has never been fired off ? only head bolted down to it ?
Old Apr 1, 2003 | 04:08 PM
orange.honda's Avatar
Default Re: Headgasket reuseable ? (zilverz)
i wouldn't reuse it. it is already molded from being tightend once it needs a new one probly to make a proper seal
Old Apr 1, 2003 | 04:09 PM
Ricey McRicerton's Avatar
I wouldnt....once the head has been torqued down it has crushed the gasket...once you take it off I wouldnt imagine that it would all come up in one peice...
Old Apr 1, 2003 | 04:12 PM
ejprimo's Avatar
Default Re: Headgasket reuseable ? (Ricey McRicerton)
get a new one.
Old Apr 1, 2003 | 06:40 PM
TimoneX's Avatar
New User
Default Re: Headgasket reuseable ? (ejprimo)
Copper spray it w/ 2-3 layers on each side and re-use it. I've re-used my current one 2x w/ a high compression motor. Don't waste your money.
Old Apr 1, 2003 | 07:43 PM
jeffreytard's Avatar
Default Re: Headgasket reuseable ? (TimoneX)
I have also re-used the steel head gasket two times.
Old Apr 1, 2003 | 09:31 PM
zilverz's Avatar
never heard of the copper spray ... what does it do ? where can it be found ?
Old Apr 1, 2003 | 10:33 PM
deepgreengsr's Avatar
conducts heat, napa
Old Apr 1, 2003 | 10:44 PM
MikeSarr_GSR's Avatar
Default Re: Headgasket reuseable ? (deepgreengsr)
buy a new one or get owned
Old Apr 1, 2003 | 11:37 PM
leadfoot78's Avatar
Default Re: Headgasket reuseable ? (MikeSarr_GSR)
**** just buy a new one its only $60. You will be grad you did.
Old Apr 2, 2003 | 07:56 AM
zilverz's Avatar
Default Re: Headgasket reuseable ? (leadfoot78)
If i get a new one .. should i spray it with copper as well ?
Old Apr 2, 2003 | 08:08 AM
Kataku2K3's Avatar
Yup... It helps aid the the seal...
I never reuse headgaskets... As TimoneX said it is possible to reuse but I just never do... $60 isn't that bad, and if you're not planning on pulling the head for awhile why not just go with a new one... This is the Permatex Copper Spray I use...
Old Apr 2, 2003 | 11:07 AM
zilverz's Avatar
Default Re: Headgasket reuseable ? (Kataku2K3)
thanks Kata ..and everyone else for the time and effort to assist
Old Apr 2, 2003 | 11:28 AM
illi Adik's Avatar
Throw a new one on.
Old Apr 2, 2003 | 09:32 PM
TimoneX's Avatar
New User
Default Re: Headgasket reuseable ? (Jackson4Door)
The cost of head gaskets add up quickly, and sprayed and installed properly I've yet to see one fail. I'm into doing things right, but I also despise waste, and if I used a new head gasket every single time I've taken one of my Hondas apart it'd have cost me several hundred dollars better spent elsewhere.
I too use the permatex copper spray, it stays tacky and works perfectly.
xrated1
Jul 13, 2009 07:49 PM
krisfnbs
Dec 17, 2008 09:03 AM
boomersz
10
Apr 11, 2007 04:37 PM
Rob Dizzle
Jun 30, 2003 03:57 PM
crxONcrack
Mar 17, 2003 08:36 AM
