Where do I get o-ring to fit DSM injector into B16A??
Old Apr 1, 2003 | 07:31 AM
evo's Avatar
evo
New User
Default Where do I get o-ring to fit DSM injector into B16A??
Where can I get o-ring to fit DSM injector into B16A, has any rings from others car or other Honda fit??
Old Apr 1, 2003 | 08:24 AM
92SiB18C1's Avatar
Default Re: Where do I get o-ring to fit DSM injector into B16A?? (evo)
Are you talking about the ring that goes inside the block? If that the case then you can use your honda one. Just take it out. Trim it a lil, just a lil to fit over the DSM or you'll have a vaccumm leak. So take off a lil, try on the injector, then take off a lil more.
Old Apr 1, 2003 | 09:42 AM
dfoxengr's Avatar
goto napa they have injector seal kits
Old Apr 1, 2003 | 10:11 AM
evo's Avatar
evo
New User
Default Re: Where do I get o-ring to fit DSM injector into B16A?? (hybridvteceg)
I try thanks
Old Apr 1, 2003 | 12:21 PM
evo's Avatar
evo
New User
Just installed 390cc DSM injectors it started at 1st time then stall never start again, what could it be?? (everything run prefect before install)
I'm runnng Mugen prog chip, stock fuel pump.
thanks
Old Apr 1, 2003 | 12:47 PM
evo's Avatar
evo
New User
Just installed the DSM 390cc injectors it started at 1st time then stall never start again. It has Mugen chip and stock fuel pump.
Anything to do with the fuel pump because not enough pressure?? (it was OK with stock injectors).
Any idea??
Old Apr 1, 2003 | 01:57 PM
Jeff C's Avatar
What are you using to take out the extra fuel that the injectors are supplying?
Old Apr 1, 2003 | 10:57 PM
evo's Avatar
evo
New User
Default Re: Where do I get o-ring to fit DSM injector into B16A?? (Jeff C)
b16a with CTR piston, JUNIII, mugen HQ, FPR, VAFC etc...
Would the car too rich that's why the car wouldn't start??
Old Apr 2, 2003 | 07:51 AM
Jeff C's Avatar
What do you the afc settings at? What -%?
Old Apr 2, 2003 | 01:03 PM
evo's Avatar
evo
New User
I set at 0% initally then reduce to 10% then 20% still not start, by the way i've got the stock fuel pump, should I upgrade the fuel pump to 250l/hr??
Old Apr 2, 2003 | 01:07 PM
dfoxengr's Avatar
u need to reduce to -31% and upgrade fuel pump
[Modified by hybridvteceg, 5:09 PM 4/2/2003]
Old Apr 2, 2003 | 02:58 PM
lsvtecvx's Avatar
Evo, did you wire in the resistors? what year is your car
Old Apr 2, 2003 | 10:21 PM
evo's Avatar
evo
New User
Default Re: Where do I get o-ring to fit DSM injector into B16A?? (lsvtecvx)
My car is JDM EF9 OBD0 I guess they're plug + play, rite?
delinquent
Mar 22, 2010 11:17 AM
SpOoLiNg CiViC
18
Apr 28, 2006 03:33 PM
Schister66
Dec 2, 2005 05:22 PM
gtcali
Jan 17, 2002 12:19 PM
