93 accord DIED!
Old Apr 1, 2003 | 06:13 AM
jlicks12's Avatar
Default 93 accord DIED!
I pulled out of my space this morning and made it about 1/8 of a mile down the street and the motor just shut off. The car cranks normally, but no start. I'm thinking its the fuel pump, but who knows. Any idea what may be wrong? Any help would be great!
Thanks,
John
--and yea- there's gas in it---
Old Apr 1, 2003 | 06:14 AM
carolinaACCORD's Avatar
Default Re: 93 accord DIED! (jlicks12)
if you just switch the car to the ON position, do you hear the fuel pump prime?
Old Apr 1, 2003 | 06:34 AM
jlicks12's Avatar
Default Re: 93 accord DIED! (carolinaACCORD)
I didnt check. That sounds like a good place to start, but is the pump under the hood, in the tank, or next to the tank?
Old Apr 1, 2003 | 06:56 AM
it is in the tank.
Old Apr 1, 2003 | 06:59 AM
jlicks12's Avatar
thanks for your help, I appreciate it. I was told there was an access panel under the trunk mat. Is that true?
Thanks again,
Brad
Old Apr 1, 2003 | 07:03 AM
optimis's Avatar
Hey I just changed my fuel filter and if you losen the top screw on the filter, the one that goes to fuel rail and injectors, fuel should come spewing out. That is just pressure being relieved. Now turn your engine over and fuel should do the same thing, spew out, but your car wont start. That well definetely tell you if its your pump.
I have a 93' LX and the filter is on the passenger side engine compartment right on the firewall. I should be below a box of sensors. The pump is definetly back farther. I would have to get my car on a lift and follow the lines. I'll get pics when I get home.... if you even want to try this method..
Old Apr 1, 2003 | 07:05 AM
optimis's Avatar
Default Re: 93 accord DIED! (optimis)
dont know about the access panel in the trunk but its worth a try...
Old Apr 1, 2003 | 07:16 AM
jlicks12's Avatar
Thanks- This car is becoming a pain in the ***!!!!!!
First the drivers window wont work-replaced switch pod
Muffler fell off- fixed that
Now this! All within a week
AHHHHHH!!!!!!!
I think I'll try and fix it in this order-
check spark
check pump
then crank sensor
Thanks all for your help-
-John
Old Apr 1, 2003 | 07:20 AM
optimis's Avatar
How many miles do you have on it?
bummer that it all happens at once
Old Apr 1, 2003 | 07:35 AM
yes there is an access panel in the trunk, right up next to the back seat.
it's how you change the pump, too.
and if you havent checked to see if there is spark, that's the first thing to check.
Old Apr 1, 2003 | 10:01 AM
RotaryBzzz's Avatar
broken timing belt?
Old Apr 1, 2003 | 11:49 AM
riceinjected's Avatar
I've had a simular promblem. It was the ignition.
Old Apr 1, 2003 | 03:14 PM
patastinky's Avatar
Default Re: 93 accord DIED! (RotaryBzzz)
broken timing belt?
yup check your distro cap too . and ignitor!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 1, 2003 | 07:48 PM
Blitzed's Avatar
Default Re: 93 accord DIED! (patastinky)
I have had the problem twice. once it was the coil in my distributor the next was my fuel pump.
Old Apr 2, 2003 | 07:49 AM
jlicks12's Avatar
Default Re: 93 accord DIED! (Blitzed)
Ok- The first thing I checked was spark and voila- none there. The plugs are saturated with raw fuel, and there is an odor of gas at the tailpipe so I'm assuming the pump's ok. I downloaded from autozone the procedure for checking the ignition module and coil, and have yet to do that. People are also saying that the crank sensor on these model accords are notorious for going bad, and most other forums the guys are showing the same symptoms- drive a few miles and the car suddenly dies.
First things first, i guess
definetly getting wasted after this
heman90210
Sep 12, 2012 09:17 PM
89b20crx
Mar 8, 2011 09:54 AM
hermtm2
23
Apr 8, 2009 06:17 PM
RA12825
Jan 29, 2007 08:51 PM
hotimportcrx
Oct 5, 2004 05:18 PM
