Bedding in Brake Pads
Old Mar 31, 2003 | 10:49 PM
Gen5lude's Avatar
Default Bedding in Brake Pads
Do I need to bed in brake pads that are intended for normal everyday driving. These pads are axiss ultimates
Old Mar 31, 2003 | 10:50 PM
Gen5lude's Avatar
Default Re: Bedding in Brake Pads (Gen5lude)
I meant that the pads are going to be used for normal everyday driving.
Old Apr 1, 2003 | 04:48 AM
Muckman's Avatar
Moderator in Chief
Deffinitly YES with the Axxis Ultimates! Thats why they come with bedding instructions! They absolutey suck before they are bedded.
Axxis Ultimates are not an "everyday normal" driving pad but a high performance street pad/light autocross pad.
[Modified by Muckman, 8:49 AM 4/1/2003]
Old Apr 1, 2003 | 12:05 PM
Gen5lude's Avatar
They come with bedding instructions? The pads I bought didn't come with any. What is the manufacturs suggested bedding in instructions?
Old Apr 1, 2003 | 01:04 PM
vactor's Avatar
neither did mine. but bedding in is usually the same for all pads. do a couple of easy 60 - 0 stops, then a few HARD 70-0 stops (pads should be smokin' and stinkin' bad at this point). then drive around for 10 minutes using the brakes as little as possible, and then park overnight. you want to start by evenly heating the pad. then get the material hot enough to vaporize the adhesive compound leftover, then cool pad evenly, then let the pad cool completely. this has worked very well for all of my brake pads.
Arsenal
Nov 30, 2006 12:50 PM
B18c5__Owns
Mar 24, 2006 01:08 PM
MaddMatt
25
Mar 7, 2002 03:51 AM
