keep the fuel pump or ditch it? w/ 450's?
Old Mar 31, 2003 | 08:49 PM
ridnmyhonda's Avatar
Default keep the fuel pump or ditch it? w/ 450's?
i'm going dsm 450's w/ fpr should i ditch the pump or keep it?
Old Mar 31, 2003 | 08:54 PM
keebler65's Avatar
Default Re: keep the fuel pump or ditch it? w/ 450's? (ridnmyhonda)
with 450's, there is no need to upgrade from a stock fuel pump. you can keep the pressure stock since the injectors will be flowing more.
Old Mar 31, 2003 | 09:31 PM
Default Re: keep the fuel pump or ditch it? w/ 450's? (keebler65)
thanks anybody else
Old Mar 31, 2003 | 09:57 PM
TurboJesse
Guest
Posts: n/a
nope he pretty much summed it up
Old Apr 1, 2003 | 12:31 AM
filthy scarecrow's Avatar
Default Re: keep the fuel pump or ditch it? w/ 450's? (Mpir3)
if you're going over 7psi i would upgrade to at least a GSR pump. (or you can add a second pump in the tank with the stock one like the supra guys do- for $20 on ebay you can have enough fuel to run upwards of 25psi of boost.. )
Old Apr 1, 2003 | 01:00 AM
T-Blaze's Avatar
Default Re: keep the fuel pump or ditch it? w/ 450's? (filthy scarecrow)
I second the Filthy ScareCrow... If ur gonna boost higher get an uprated fuel pump like a Walbro! Your only gonna need one later so u might as well get one now and be prepared...
Todapwr
May 12, 2004 07:51 PM
Screamer
Jun 18, 2003 09:17 AM
1tyme
Oct 22, 2002 12:36 PM
