max boost on d16z6
swap in ls rods and pistons and you can run 18 psi, my friend did it. w/ just FMU and check valves so if you run a good management, can run almost 20 psi, just fine, make over 2fity at the wheels
just my .02.
just my .02.
Whats the safest amount of boost the stock d16z6 can handle?
12 psi as a max drag strip run
on stock setups of internals...
some engines might survive more than that. but over 12psi will require a good engine management
8-9 psi daily driven
im probably going to do a junkyard (custom) turbo
Black95CivicEx
Dec 30, 2008 02:11 PM
boostedsohc91hb
14
Feb 13, 2004 09:13 PM
soontohavecrx
Aug 27, 2002 08:38 PM
