What all do I need to do a 5 lugg conversion on a EK * yess I did a search*
well buddy of mine wants the 5 lugg conversion on his 00SI thing is I dont know exactly what all is needed to do the swap over and what parts u keep on your suspention. I did a search * 5 lugg conversion* and nothing came up so if u can help me it would be great pics as well. I found this on a sight and wondered if this is all that u would need
-incl: frnt knuckle assemblies w/brake components, rear trailing arm assemblies w/brake components... not incl:brake lines, lower control arms, or sway bars. LCA, shocks, and sway bars can be purchased separately. for JDM wheel options, email us.
Thanks for any help
chris
Thanks for any help
chris
https://honda-tech.com/zerothread?id=426683
use the search...the cars are differest but the info is useful. this is the first thread that came up when i searched. and it's LUG, not LUGG...
[Modified by black92si, 2:23 AM 4/1/2003]
looked at all the treads but still did not help what needs to be done to put 5 lug on a SI.
Didnt some guy on here wiht a red Si put 5 lug on his SI and the JDM OEM 16's? anybody knwo his screenname
dude, it's easy.
All you need is the spindles, breaks and the rear trailing arms.
Hopefully they have the ebrake cables still, if not, you should be able to use your stock Si ones.
Same with the brake lines.
Don't worry about the LCAs, everything will bolt up fine.
dude, it's easy.
for u now I can get my buddy off my *** thanks alot.I was also wondering if we could use the stock SI calipers front and back with the ITR set I would think it would not be a prob. BUddys on a budget with this thanks again
1337 Si
19
Nov 17, 2003 02:48 AM
1337 Si
Nov 15, 2003 12:00 PM
