Whats the compression suppose to be on built h23???
Old Mar 31, 2003 | 02:05 PM
IloveNewt's Avatar
Default Whats the compression suppose to be on built h23???
This is on an h23 with GE sleeves, stock bore JE 9:1. Im getting 2 answers 160 and 180. Which is it?
Old Mar 31, 2003 | 02:50 PM
BoostedH23a1's Avatar
Default Re: Whats the compression suppose to be on built h23??? (MordecaiPSI)
180 would sound moreso right to me.. but i dont have 9:1.. my stock numbers are 210
Old Mar 31, 2003 | 03:10 PM
IloveNewt's Avatar
Default Re: Whats the compression suppose to be on built h23??? (BoostedH23a1)
Any reason u think 180 is more-so right? Is there some sort of formula for this?
Old Mar 31, 2003 | 06:44 PM
Reyke's Avatar
if I am correct the stock CR is 9:1 and thus shouldn't really yeild any powr gains if your only installing factory spec forged internals if anything the only boost in power you should see is the engine going from its tired state to a refreshed state due to fresh internals, so in my opinion you should be at stock levels of 160 pushing 165 if you're running total seal rings which i have seen noticeable increases in hp from dyno charts
Old Mar 31, 2003 | 07:29 PM
IloveNewt's Avatar
Default Re: Whats the compression suppose to be on built h23??? (IOWNU)
i lost hp when i went to 9:1. No way stock compression ratio was 9:1.
Old Apr 1, 2003 | 07:51 AM
DLB1994's Avatar
10.2:1 235psi
Old Apr 1, 2003 | 09:19 AM
IloveNewt's Avatar
Default Re: Whats the compression suppose to be on built h23??? (DLB1994)
10.2:1 235psi
Thanks. Those r awesome numbers, whats ur setup?
Also anyone have compression numbers on a healthy built 9:1 h23?
Old Apr 1, 2003 | 01:40 PM
LudEcrous's Avatar
you are wrong...the stock compression ratio of the h23 is 9.8:1
Old Apr 2, 2003 | 01:21 PM
Reyke's Avatar
yeah you're right my mistake, oh wait hmm are you sure becuase i just read it was more so 9.6:1 either way you dropped your compression guy and so thinking 160 or 180 is totally off you're probably making 155 of course this is just a guesstimate if i was an engineer I could give you more exact numbers but neverthless you can expect a power drop
oilguzzler
Nov 17, 2005 07:52 PM
angela_itr
May 27, 2005 01:51 AM
Quade
Apr 5, 2005 03:12 PM
IloveNewt
Mar 31, 2003 02:46 PM
immortal
Nov 6, 2001 08:05 AM
