Air condition removal help
Well, i have removed everything from the engine bay.
What do i remove behind the dash?
I have removed the evaporator, the thing that the ac lines connect too.
Now there are 2 white boxes. One to the left and one to the right.
Which one do i remove? I want to keep my heat blower. I need some kind of ventilation.
What do you use to plug up the big hole in the firewall that the ac lines use to go?
thanks
thanks
I saw your Q? in the other thread...sorry I did not reply.
I could get you that info tomorrow when I get the instructions (Im at work now) in front of me. I will check this then, and if you still dont have any answer I will try to help.
You take out the evaporator and replace it with this hose type thing. It just replaces the evaporator with a big hose. The hole in the firewall gets plugged up with a rubber grommet. You may be able to find those from the dealer. If not just get them from whoever you sell your A/C to.
gsr98vtec
Jul 11, 2002 09:16 PM
