blow off valve sounds changed???? whats up with this>??
Old Mar 31, 2003 | 11:21 AM
dc2pffsssttt's Avatar
Default blow off valve sounds changed???? whats up with this>??
Heres the deal. when I installed my turbo, I was not running a filter on my turbo, just a mesh screen, but only for a short while. I have a HKS SSQV. The sound of the blow off valve was fine, made the sound its supposed to make. I put a filter on the turbo soon after and now it makes a different sound once in a while. Instead of the regular straight whistle it makes, it sounds like the one on the supra in the fast and furious, where it makes a sputtering sound, only it doesnt always make this sound, once in a while it does just the regular whistle. Any ideas why its doin this?
Old Mar 31, 2003 | 12:18 PM
Default Re: blow off valve sounds changed???? whats up with this>?? (dc2pffsssttt)
anybody???
Old Mar 31, 2003 | 12:28 PM
ASDspeedshop.com's Avatar
any difference in boost? turbo lag? anything? (since the filter)
Old Mar 31, 2003 | 01:08 PM
SiRkid's Avatar
part throttle/lower boost?
seems fine to me.
they do that sometimes when not at full boost.
Old Mar 31, 2003 | 01:14 PM
BoostingSnail's Avatar
Default Re: blow off valve sounds changed???? whats up with this>?? (SiRkid)
I started a post on this a while back...I think it might be archived now...I tried to do a search for it but said search was disabled..but if you want to try later search for wastegate flutter....turns out its not the wastegate...its actually the BOV...everyone seemed to agree that the BOV doesnt get a good vacuum source when it makes the fluttering sound..so make sure your vacuum line is good and secure then maybe try a new source
Old Mar 31, 2003 | 01:55 PM
Doodoo's Avatar
Default Re: blow off valve sounds changed???? whats up with this>?? (BoostingSnail)
It has to do with load. I get two different sounds at 9psi and 14psi. Very low load mine will flutter, sometimes it doesn't just because I let off at a different amount of boost. Very strange but normal.
buddha1320
Jul 20, 2005 09:03 AM
Ri5e
Dec 27, 2003 11:27 AM
freeplay
Aug 22, 2003 04:08 AM
2000GSRT
Apr 26, 2003 10:09 PM
1tyme
Mar 16, 2003 08:30 AM
