How can you tell what size wastegate you have by looking at it?????
Old Mar 31, 2003 | 10:50 AM
turbochic's Avatar
Default How can you tell what size wastegate you have by looking at it?????
I got all my parts in the mail last weeke and I was trying to figure out what size wg I got, on the top of it there is a sticket with Turbonetics Inc. , Pat. Pending, Deltagate Mark II, P/N10101, and that is it!!! nothing else anywhere, I bought the kit used so I cant contact any store or anything, just wondering if you guys knew of a way to tell. Thanks.......
Old Mar 31, 2003 | 11:30 AM
falcongsr's Avatar
What is this crap?
Default Re: How can you tell what size wastegate you have by looking at it????? (fmaxturbochic)
why cant you call and ask turbonetics? http://www.turboneticsinc.com
but someone on here would probly be able to tell you with the right info...
Old Mar 31, 2003 | 11:36 AM
SinSeven's Avatar
Default Re: How can you tell what size wastegate you have by looking at it????? (falconGSR)
you know what? you and i are in the same predicament. My deltagate has the same sticker, except mine has another little sticker by the vacuum port that says 6 or 9.......so i don't know if it's a 6psi spring or a 9. The only way to really find out is to get it running and get a boost gauge. Something i haven't done.
Old Mar 31, 2003 | 12:32 PM
Flamenco-T's Avatar
Default Re: How can you tell what size wastegate you have by looking at it????? (Boosted-DA9)
deltagate are adjustable wastegate, you can adjust the diapghram from 6 to 9 psi..
stan
Old Mar 31, 2003 | 12:51 PM
SinSeven's Avatar
Default Re: How can you tell what size wastegate you have by looking at it????? (Flamenco-T)
Stan, it's me Luis. I changed my username to boosted-da9. Hahahah. i thought it fit me better. Hey how do you adjust it? i know it's the top bolt and nut, but do you looson it for more boost or tighten it?
By the way, the fittings are working like a charm .
Old Mar 31, 2003 | 01:00 PM
accordfreak's Avatar
tighten for more boost
Old Mar 31, 2003 | 02:43 PM
turbochic's Avatar
I know from the guy I bought it from, he said it is set at 9 psi. but i have seen some posts saying, "35mm wastegate, 40mm wastegate" does that mean anything that I need to know about?
97gsrki
Jan 21, 2006 09:22 PM
nsxmatt
Oct 19, 2005 07:38 AM
dan_w_82
Mar 29, 2005 02:55 PM
siblues
Dec 27, 2004 11:13 AM
2muchPSI
Oct 19, 2003 07:07 PM
