Does anyone know how to work the Greddy Turbo Timer
Old Mar 30, 2003 | 08:21 AM
incognitoracerr's Avatar
Default Does anyone know how to work the Greddy Turbo Timer
Guys....I have the greddy auto turbo timer and the instructions suck....(or maybe I can't follow them...lol)....how do i set the timer so that when i turn the ignition off the car stays running?
Old Mar 30, 2003 | 09:14 AM
FORCED FED TEG's Avatar
New User
Default Re: Does anyone know how to work the Greddy Turbo Timer (incognitoracerr)
If every thing is wired up right it should work automatically. You can ad time if you hit SELECT to get in one of the modes A-L, A-H, P-1 or P-2. Then hit TIME to ad more time to the count down. If you need more help let me know or try asking in the Forced Induction form.
Old Mar 30, 2003 | 09:22 AM
Default Re: Does anyone know how to work the Greddy Turbo Timer (FORCED FED TEG)
Hmmm...i do put everything like you just explained...and the wiring is correct...i just don't know if i may be doing something wrong with the time setting...after you set the time how would you know if the timer is activated so that when you shut the car down it stays on?...
Old Mar 30, 2003 | 09:51 AM
New User
When turn on your car hit the TIME button it should ad time by 10 sec. each time. The timer should show the time (0.30 like this) When you turn the key off the timer will count down and the car will run till countdown is done.
Old Mar 30, 2003 | 11:32 AM
I think I know what the problem may be...when I turn the car off the turbo timer shuts off also so maybe I have to connect the positive wire to something that does not loss electrical current when I turn the ignition key off....where would you suggest I connect it too if this is the case?...whats your wire setup....
Old Mar 30, 2003 | 11:51 AM
M-EJ1's Avatar
If the turbo timer turns off immediately when the car turns off, you either need to turn it "on" by pressing the power button when the car is running then setting a time, or you don't have it wired right.
I had a similar problem... when I first wired it, I wired it according to Greddy's "Four Wire Ignition" diagram... when, infact, my car (95 civic) has a five wire ignition. So check that out as well, you might need to do some rewiring.
Old Mar 30, 2003 | 12:01 PM
New User
From the timer to the ignition. Red to White, Green to Black/Yellow, Blue to Yellow, Black to ground
Old Mar 30, 2003 | 12:03 PM
Hey I appreciate it...I will re-wire and let you know how it goes...thanks a million...I have a 1994 ex civic so the wiring is the same..thanks a lot
Old Apr 2, 2003 | 07:59 AM
Hey thanks for the re-wiring diagram....it worked and I finally got it to work...now I don't have to sit in the car anymore in this cold weather...lol...thanks...by the way...do you have the profec b installed in your car?...i need a little help with that also
phiberoptik
Nov 6, 2005 06:26 PM
zebt66
Feb 21, 2005 08:21 AM
alfee
Jan 4, 2005 11:02 PM
whiteblurr
Feb 24, 2004 10:54 AM
gsrcivict
Jul 10, 2003 12:49 PM
