Got a little problem-Need your help...
Old Mar 29, 2003 | 07:35 PM
SpdFrk's Avatar
Default Got a little problem-Need your help...
Okay I got coilovers for my hatch. I tried to install them today but the rear bottom bolt that holds the shock will not come off. This is for the rear shocks. What should i do??? any suggestion would be appreciated??
Old Mar 29, 2003 | 08:53 PM
boostsohfast's Avatar
Default Re: Got a little problem-Need your help... (SpdFrk)
First try to lube that bitch up. Those bolts are known for breaking. What tools did you try so far? The last time I did one on my buddies car, I used an impact gun and kept forwarding and reversing the bolt while bangin on the LCA with a hammer. When the bolt came out it was actually twisted so I got lucky. If you don't have access to a gun that I guess try a breaker bar, but just be as careful as possible in not trying to break the bolt.
Old Mar 29, 2003 | 09:28 PM
Nine's Avatar
Default Re: Got a little problem-Need your help... (boostsohfast)
I broke mine but it didnt cost much to replace.. WD40 is ur friend and so is patience.
Old Mar 30, 2003 | 12:10 AM
ridiculous's Avatar
Default Re: Got a little problem-Need your help... (Nine)
huge breaker bar, and slowly put more and more pressure on it, the quick pressure can break that bitch off, good luck! back ones always gave me trouble too, had my front low and the back stock for about a week till i could get that bolt loose
Old Mar 30, 2003 | 12:26 AM
PotatoePAPA's Avatar
Default Re: Got a little problem-Need your help... (ridiculous)
ok, this is probably the 4th post I have seen today about the bolts in lca's. SEARCHING is your FRIEND...
Old Mar 30, 2003 | 06:51 PM
JustinL's Avatar
Default Re: Got a little problem-Need your help... (EG CoUpe)
i broke the bolt too. how do you get it out once the head is broke off?
Old Mar 31, 2003 | 06:18 AM
VRD^don's Avatar
Default Re: Got a little problem-Need your help... (pyro_assassin)
broke it too, ended up breaking the whole LCA when had everything finished. took it out for a test and it broked.. sucked cost $600 to replace it...
Old Mar 31, 2003 | 06:21 AM
Ya@inlinePRO's Avatar
Default Re: Got a little problem-Need your help... (sohc_vtec)
if you use the breaker bar technique, don't JUMP on it. apply steady force to it, it should come off, DURA LUBE and WD-40 and patience.
Old Mar 31, 2003 | 08:47 AM
Damon's Avatar
Default Re: Got a little problem-Need your help... (kwik2nec)
wd-40 works great, but if you can find a product called Liquid Wrench I like it better. Hard to find this stuff tho.
IAcivicEK
Jul 1, 2007 07:37 PM
kyorishin
Apr 11, 2006 11:02 PM
Vtecfool
Mar 14, 2004 04:31 AM
Batoutahell
Oct 15, 2002 04:33 AM
92Si
Jul 25, 2001 10:37 AM
