hf manifold--14b turbo adapter plate
Old Mar 29, 2003 | 07:31 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default hf manifold--14b turbo adapter plate
somebody on ebay sells the adapter plate that bolts a T25 to a hf manifold, will this same adapter work to bolt my 14b to my hf manifold?
Old Mar 29, 2003 | 08:13 PM
Guess whos bizzack
Default Re: hf manifold--14b turbo adapter plate (Y49CRXSIZC)
abaz you can answer this cant you?
Old Mar 29, 2003 | 08:14 PM
Tinker219's Avatar
I believe it will work...on Homemadeturbo.com forums, i asked if the T25 had the same flange as the 14b, etc. Abaz said yes...so...yes
Old Mar 29, 2003 | 08:30 PM
AbaZ's Avatar
Now it really depends on how the adapter plate is setup, I think I know the guy you are talking about.. he sells them without pictures all the time.
You have 2 different styles of adapter plates..
countersunk style..
The bolts come in from the top side, going down (just like gary & randys plates/dropshop)
Only problem here, is the seal is shitty as hell, exhaust can sneak through the allen heads of the countersunk bolts.
This is the bottom style, basically you have to put bolts on the bottom side going through the exhaust housing threading into the plate, this requires drilling out the factory threads, and grind the housing flush (so the head can sit nicely)
http://www.homemadeturbo.com/tech_pr...ech/index.html
This is a little adapter article I did..
Also, here are a few guys plates (counter sunk style) that have had exhaust leaks,
http://www.norcalcrx.org/spoon2/pics/turbo.jpg
http://images.cardomain.com/installs...58_93_full.jpg
Hope that helped,
Jeff Frank
[Modified by AbaZ, 5:31 AM 3/30/2003]
Old Mar 29, 2003 | 08:36 PM
AbaZ's Avatar
oops as I forgot to say.. if it was the 2nd style plate, it really wouldnt work, since the 14b only has 3 access points.
But overall the T25/14b flange is the pretty much the same thing.
Jeff
Old Mar 29, 2003 | 10:16 PM
Tinker219's Avatar
Default Re: hf manifold--14b turbo adapter plate (AbaZ)
Abaz= for tech articles
Old Mar 30, 2003 | 08:48 AM
Guess whos bizzack
Default Re: hf manifold--14b turbo adapter plate (Tinker219)
ok so do you have the email of someone who sells the one that will work, if not, is it really that bad just to weld the turbo to the manifold itself?
Old Mar 30, 2003 | 11:08 AM
Guess whos bizzack
up
Old Mar 30, 2003 | 11:22 AM
QCKGSR's Avatar
yea
Old Mar 30, 2003 | 12:03 PM
shortyz's Avatar
Default Re: hf manifold--14b turbo adapter plate (QCKGSR)
goto hmt. someone might have one.
Old Mar 30, 2003 | 07:43 PM
fsp31's Avatar
Default Re: hf manifold--14b turbo adapter plate (shortyz)
Just a quick word of caution... Make sure something like this will work first.
I put a T25 on my 98 hatch with a D16Y8 (head and tranny swap), and used a STD manifold instead of the HF. It's a bit larger than the HF manifold and it flows better. I also used the O2 housing from the DSM since I didn't want the hassle of fabricating a complicated downpipe. Anyway, I did some test fitting with blocks of wood before purchasing a pre-made adapter plate and I'm glad I did. No way would one of these have worked. I ended up making my own. I had to start with a wedge shape that started at 1.75" thick and tapered to .75" thick in order to rotate the turbo away from the block.
Old Mar 31, 2003 | 01:21 PM
Guess whos bizzack
Default Re: hf manifold--14b turbo adapter plate (fsp31)
well i took it to a machine shop today to have them make me an adapter plate, i should have it back tomorrow so ill let you know how it works, he said $40 too which is good.
Old Apr 2, 2003 | 08:13 PM
@irborne's Avatar
where can i get a blank steel plate like that?
Old Apr 3, 2003 | 12:11 AM
AbaZ's Avatar
Default Re: hf manifold--14b turbo adapter plate (@irborne)
Any steel yard... Just look in your phone book, anyone who deals with steel can get you something..
its pretty cheap,
Think that cost me like 3 bucks.
Old May 20, 2003 | 03:34 PM
slywfbpsi's Avatar
Default Re: hf manifold--14b turbo adapter plate (GSRslowandswap)
dropshop.tv makes an adapter plate for the std/hf manifold for $90.
blinger
Mar 9, 2007 03:11 PM
im a monster hehe
May 31, 2006 11:06 AM
sinfulj32
Nov 14, 2004 06:53 AM
iNetForce
Apr 28, 2004 04:00 AM
kHoA DoGG
Nov 30, 2003 11:11 PM
