How to remove a sohc vtec head?
Old Mar 29, 2003 | 06:36 PM
92JDMcivic's Avatar
Default How to remove a sohc vtec head?
heading to the junyard tommorow to see if i can find a d16z6 or d16y8 head. i got a socket set should that be sufficient to remove it? also does anyone know of an aftermarket company that makes valve springs for that head? does anyone have a link to a diagram of the head? thanks again
Old Mar 29, 2003 | 06:38 PM
Skyllz's Avatar
Default Re: How to remove a sohc vtec head? (92JDMcivic)
usual tools for a honda...
10 to 19mm sockets and you should be fine.
Remeber that the 92-95 Z6 head DOES NOT have the same distributor bolt pattern then all the other D series head... damn Honda...
Old Mar 29, 2003 | 06:39 PM
Evs-One's Avatar
Solbros Owns Me
pull off valve cover- 10mm nuts
pull off timing belt cover- 10mm nuts
cut timing belt with a knife
remove exhaust manifold- 12mm nuts
remove the 2 12mm bolts underneath intake manifold- attatched to bracket
remove all wiring
crack the 14mm head bolts evenly
take out head bolts
remove head and intake mani as a whole
I had some Crower valve springs in mine and they were good
Old Mar 29, 2003 | 07:38 PM
92JDMcivic's Avatar
Default Re: How to remove a sohc vtec head? (Emerika)
"crack the 14mm head bolts evenly"
What do u mean by that ? dont i need to reuse them? should i pull off the distributor also?
Old Mar 29, 2003 | 09:55 PM
Evs-One's Avatar
Solbros Owns Me
crack as in "break loose". You don't want to take them all out one at a time, as this will leave a lot of stress in certain areas. Break them loose with a 1/4 turn until all are loose. Then work your way around loosening them all up until there is no more pressure on the head.
The dizzy can stay or come off, there's only 3 12mm bolts holding it on
Old Mar 29, 2003 | 11:05 PM
Stupid Ass's Avatar
Also... no need in cutting the TIMING BELT if its in good shape... just slide it off with a flathead..
Old Apr 5, 2005 | 08:00 AM
skater5067's Avatar
nice info will be doing this today
Old Apr 5, 2005 | 08:31 AM
Daniel san's Avatar
Default Re: How to remove a sohc vtec head? (skater5067)
I'm not sure on the exact number
this is jsut from what I remeber, jsut to give a rough reference
but loosen the bolts in this pattern
1 5 7 3
4 8 6 2
that way you wont warp the head
can someone tell how to do this exactly ? I don't have my helms with me
and I don`t think I have enough bolts
Modified by Daniel san at 5:31 AM 4/6/2005
Old Apr 5, 2005 | 09:06 AM
EVIL Hx Coupe's Avatar
Default Re: How to remove a sohc vtec head? (Daniel san)
Straight from my helms.
1. Disconnect Negative Terminal from Battery
2. Drain Engine Coolant
3. Remove Intake
4. Remove Power Steering Belt and Pump
5. Remove A/C Compressor Belt
6. Remove Alternator Belt
7. Remove P/S Pump Bracket
8. Remove Throttle Cable
9. Releave Fuel Pressure
10. Remove EVAP Control, canister hose, fuel fed hose, and breather hose.
11. Remove Brake booster vacum hose, fuel return hose, and vacum hoses.
12. Remove Water Bypass Hose, and PCV hose.
13. Remove Uppper Radiator Hose, Heater Hose, and Water Bypass Hose.
14. Remove Engine Harness Connectors and Clamps.
15. Remove Spark Plug Caps and distributor from the head.
16. Remove the upper motor mount bracket.
17. Remove Valve Cover
18. Remove Timing Belt
19. Remove Camshaft Pulley (camgear) and Back Cover
20. Remove Exhaust Manifold.
21. Remove Intake Manifold.
22. Remove Cylinder Head Bolts and then the head is out. (Unscrew the bolts in the following patter 1/3 of a turn at a time to prevent warpage.)
Old Apr 6, 2005 | 06:52 PM
CASPER_VTEC's Avatar
Default Re: How to remove a sohc vtec head? (EVIL Hx Coupe)
damn EVIL HX COUPE=== good at providing the info.
Old Apr 11, 2005 | 08:03 PM
Daniel san's Avatar
Default Re: How to remove a sohc vtec head? (CASPER_VTEC)
here ya go
Old Apr 11, 2005 | 08:25 PM
Stoich EG2's Avatar
uhhhhh, we got that 2 posts ago... hahaha
tigueremalo
12
Oct 21, 2006 04:26 PM
Strikerrr
Aug 28, 2005 11:07 AM
Copy Cat
Aug 11, 2005 07:55 PM
MugenHonda
Apr 26, 2005 03:44 PM
Layziebtnh055
Apr 13, 2004 07:09 AM
