Question about boost
I am still trying to decide between a Greddy kit, and a custom t3/t4 kit for my 99si. Everyone says more power with the latter, but if I'm boosting 10psi with a GReddy turbo, and 10psi with a Drag kit, isn't it the same, 10psi = 10psi or am I missing something. Using a boost controller you can crank up the boost...right. Forgive me if I sound stupid or if I'm missing something.
The amount of boost doesnt just determine the power that you would put out...the size of the turbo, motor, intercooler, piping, downpipe, manifold.....everything effects the amount of power the motor would produce.... i honestly think you would make more power with the Drag kit.
[Modified by BrokenVtec, 7:20 PM 3/29/2003]
Me personally, I wouldn't go with the DRAG, maybe Revhard or build a custom turbo kit myself.
I see now, if you have a two inch pipe that has 10psi of air being forced through it you won't get the volumn of airflow of a ten inch pipe that 10psi flowing through it. Just a hypothetical example. Right?
t if I'm boosting 10psi with a GReddy turbo, and 10psi with a Drag kit, isn't it the same, 10psi = 10psi or am I missing something..
the more air and fuel you can burn the more power you will make....the larger turbo will flow more then a small turbo....
GreddySi99
Jul 8, 2003 05:19 AM
DIRep972
Aug 19, 2001 01:07 PM
