VSS, speed senor problem HELP!!!!
I was wondering if anyone else is have the same problem as me and if so how to go about fixin' it...I have a '99 EX Coupe and my speedometer jumps all over the place, mainly when it is over 3000 rpm...I have replaced the actual speed sensor and the plug that plugs into the speed sensor....I was wondering if there is a possibility that two wires may be touching one another and if not what is it and how can I fix it?
[Modified by 99D16VTECCivic, 5:04 PM 3/29/2003]
Yeah...that didn't fix it...today I'm going to go out and reconnect all of the wires better...I think that two of them may be touching....
when my speedo started dying all i had to do was get oil out of the vss connector plug and everything returned back to normal. no clue how it got in there, but it fixed the problem. maybe you didn't even need to change yours?
Thanks everyone for the help...I think I found the culprit today...there was a wire that wasn't having a complete connection and I'm going to try to fix it tomorrow at work.....
i wonder if some can hlep me with my speed senor problem 4 week i put a need tranny in my civic coupe ....but tha tranny came off from a del sol si sohc... drove it and tha check engine light pop up and tha speed senor wasnt working so what should i do????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBeeKilla »</TD></TR><TR><TD CLASS="quote">
it had to be replaced b/c both the connector plug and vss itself were both corroded....i'll check to see if there is any oil in it tomorrow at work....</TD></TR></TABLE>
the nasty green/white corrosion? yeah. mine had that too. common problem.
