V-AFC trouble, need help please
I posted this already on the FI forum, but my car is grounded if i can't fix this problem:
I just finished my turbo install about 5 minutes ago, including the v-afc. However when I put in the key and turned it to the ignition setting, the v-afc's buttons lit up but the main menu did not show up. It's completely dark except the buttons which are glowing, I don't know what the hell is going on, if you can help me, please post.
Did I possibly wire something wrong? My friends and I will check again
yea most likely its ur wiring. did u ground the unit? i think u have the power wired up and all the things tapped, but maybe a loose connection somewhere. check them and let me know whats up. if i can remember theres only like 2 or 3 wires for ground connection and power. (2 grounds)
krazy
krazy
