EX-to-DX Cluster (mph/rpm)
Old Mar 29, 2003 | 09:38 AM
Loaded_Pistol's Avatar
Default EX-to-DX Cluster (mph/rpm)
the cluster on my 96 DX does not show rpm/red line.
can i get a new cluster off a civic EX and install it in to a DX model?
will i be needing any additional wires to make the rpm's functional?
Old Mar 29, 2003 | 09:49 AM
tominos's Avatar
Default Re: EX-to-DX Cluster (Loaded_Pistol)
yes it'll show rpm and everything the ex cluster has. your car is already wired for it, so straight plug and play.
Old Mar 29, 2003 | 10:30 AM
WangChung's Avatar
Default Re: EX-to-DX Cluster (tominos)
does that work for a cx also?
Old Mar 29, 2003 | 10:48 AM
JDMFreak's Avatar
Default Re: EX-to-DX Cluster (97civhatch)
if it the same year model like 96-00 it should all fit... even the cx model
Old Mar 29, 2003 | 11:11 AM
Default Re: EX-to-DX Cluster (JDMFreak)
thanx for the info.
i'll take a little trip to a junkyard on Mon. and update u if its all peaches
Old Mar 29, 2003 | 12:09 PM
Mjfan12's Avatar
how much should this cost? Cuz I need to do this too. I don't know why a damn manual car doesn't have a tach! Even my moms Civic LX has one, and that's an automatic!
What's the DX's redline on the stock engine? because obviously it's not the 7200 RPM of the EX. I have a 94 DX Coupe BTW
Shaun's Avatar
plug and play
Old Mar 29, 2003 | 12:18 PM
Targa250R's Avatar
be professional
Default Re: EX-to-DX Cluster (Mjfan12)
'94 DX redline is 6500. Get an LX cluster, it has the same engine.
Old Mar 29, 2003 | 12:41 PM
EricUSC's Avatar
Good point. Perhaps you should look for a Civic LX cluster instead since it has the same engine as a DX.
Old Mar 29, 2003 | 12:51 PM
Eibach95Civic's Avatar
Community Builder
i installed a 95ex cluster into my 95lx everything plugs and plays but a green plugin on the ex i didnt have for the lx, but everything works fine...
Old Mar 29, 2003 | 01:05 PM
WangChung's Avatar
Default Re: EX-to-DX Cluster (Eibach95Civic)
shaun, ur avitar is sssssssoooooooooooooo sweet!!!!
Old Mar 29, 2003 | 02:17 PM
97civicdx's Avatar
You can also swap your or speedo so you keep your original mileage.
Old Mar 29, 2003 | 02:23 PM
Irishweird00's Avatar
Banned
Default Re: EX-to-DX Cluster (97civicdx)
can you swap out the tach and the fuel and heat gauge from a ex and put them in a dx cluster??? or would it just be easier to swap the miles
[Modified by Irishweird00, 6:24 PM 3/29/2003]
Old Mar 29, 2003 | 02:39 PM
RickChew's Avatar
Default Re: EX-to-DX Cluster (Irishweird00)
The gauges cant be swapped into a DX housing (the part that holds the gauges) you must use an EX one. You can use your stock speedo to keep your miles correct, so just find an EX(or other civic cluster w/ tach) and swap over your speedo...where could you find one cheap....wait a second! lol, I have one for sale. It is a 00 Civic EX cluster that comes complete with everything that you need to swap out your DX to an EX except for the fuel/temp gauges which can be purchased from a junk yard for a few $. Id let it go for $20 shipped. It will include the tach and a speedo, the gauge bezel, & the clear plastic cover. Rick
Old Mar 29, 2003 | 06:16 PM
Mjfan12's Avatar
Default Re: EX-to-DX Cluster (RickChew)
Why would using your stock speedo keepthe miles correct? Why would another not?
Old Mar 29, 2003 | 06:25 PM
Targa250R's Avatar
be professional
Because the odometer is integrated into the speedometer assembly.
Old Mar 29, 2003 | 06:35 PM
Mjfan12's Avatar
Default Re: EX-to-DX Cluster (Targa250R)
thanks for the reply
Old Mar 31, 2003 | 12:21 PM
i need a new speedometer (the whole unit) since mine on a 96 DX coupe does not work. Are u saying that the entire speedometer unit off EX model will not work/fit or wire up correctly???
Do i need to buy a new DX speedometer and add rpm cluster off EX model instead??? Why will the EX model speedometer not work on DX model???
Old Mar 31, 2003 | 12:35 PM
young grasshoppa's Avatar
You can only swap the speedometers between the two clusters. That is the only part of the cluster that will intergrate. ie: You cannot put the DX fuel gauge into an EX cluster and vice versa.
Old Mar 31, 2003 | 12:58 PM
Default Re: EX-to-DX Cluster (young grasshoppa)
so i buy a new DX speedometer and substitute clusters off EX model??
some1 post pics of two speedometers so i know what the hell i am doing prior to me wasting $50 on the new speedo at the junkyard. I was suppose to get today EX model speedo, but now change of plans since it'll not work if i understand it correctly.
Old Mar 31, 2003 | 01:05 PM
i don't mean to confuse any1 in what i am tryn to do. I figured i throw away the old DX model speedo and throw in a new EX model speedo without touching the clusters...I thought it could be a direct swap with a few wires to play around in order to get the rpm's work on DX model...shitttt, can i do this and will it be all functional Or NOT
[Modified by Loaded_Pistol, 10:16 PM 3/31/2003]
Old Mar 31, 2003 | 01:45 PM
Buy an EX cluster and it will plug right in to a DX dash. Everything will work.
Old Mar 31, 2003 | 02:13 PM
RickChew's Avatar
The speedometer can be swapped between clusters. The tach wont plug into the DX cluster though. If you need a new speedo let me know, I have 2 spares. Thanks! Rick
yankeefan855
May 15, 2010 03:55 PM
eG6haTchY
Aug 12, 2008 04:32 PM
lumpylude
Oct 15, 2007 03:30 PM
foomashoo
Nov 23, 2004 08:56 AM
gondzur
Aug 30, 2004 08:24 PM
