help help i just pulled of my weel an two studs broke@!
help i have a 2 door eg! i just broke off 2 front studs on the passeger weel what to door how to get thim off! we pulled off the wheel an pulled every thing lose! what to do next????
2 methods,
1. take the whole knuckle off and take it to a shop and have them press out the old studs and press in the new ones.
2. take the rotor off so the hub is just there, then hammer the broken studs out, then place the new studs in from the back, try to tap them in with a hammer, then put lug nuts on them and tighten them so th lug nuts pull the stud in to place, then take the lug nuts back off and replace the brake rotor and everything else.
the second method is the cost effective and i think its easier, you can pick up studs at like autozone for 1.50 each.
