What catch can do you use?
Just wondering what you guys/gals use. Im not sure if baffled is worth it or now. SRR ones are only about 60 bux...
So ya, What brand?, is it baffled or not? and do you like it?
EDIT: this is for my daily driver. not tracked at all. Maybe in the future it will.
Just that I took off my IM this week..and oil dripped out, lol, PCV valve was replace like 3k ago...it sounds bad already tho...doesnt move inside. So ya..and I burn oil...imagine that..
[Modified by ragejed, 10:03 AM 3/29/2003]
Baffling of the oil can prevents blow by of oil "mist" from the inlet to the outlet of the can. Someone once told me that the SSR can has 90° elbows inside the can so baffling would not be required in this case.
PS - I've never seen an SSR catch can before so I'm not sure if those elbows exist in the can or not.
i'm not sure what the purpose is behind a baffled catch can...can someone elaborate on this?
Larger image (cut and paste link): http://www.imagestation.com/picture/...2.jpg.orig.jpg
So anyone use the SRR ones?
I emptied my catch can the other day (haven't done that in approx 3000 miles). There was 250 ml of oil in there at least. I'm using a cusco one.
If I had to purchase one now, I would go with the Jaz.
The cusco one was a gift
[Modified by Tommy_Gunns, 11:59 PM 4/1/2003]
however I like the Endyn Moroso idea where you don't have to drain the can since the collected oil is sucked back into the pan....
i am using the cusco one too how do you empty it??
This may sound stupid, but whats the reason for a catch can? I see and understand how it works. Looks like its help keep the intake manifold clean? I am new to this idea.
