How do you remove head oil control orifice?
Old Mar 29, 2003 | 07:35 AM
B19CivicHB's Avatar
Default How do you remove head oil control orifice?
I have a new o-ring for the head oil control oriface but I can't get the damn thing out! Is there a secret to removing it? Any help would be GREATLY appreciated!
-Nick-
Old Mar 29, 2003 | 11:45 AM
B19CivicHB's Avatar
Default Re: How do you remove head oil control orifice? (B19CivicHB)
No one...?
Old Mar 29, 2003 | 02:55 PM
B19CivicHB's Avatar
nevermind, figured it out
Old Mar 29, 2003 | 03:15 PM
Chiovnidca's Avatar
Did you use a screw?
Old Mar 29, 2003 | 04:58 PM
B19CivicHB's Avatar
Default Re: How do you remove head oil control orifice? (TurboD16Chiovnidca)
naw, I have this tapping tool that is threaded like a screw. Came out like a charm!
Old Jun 6, 2003 | 04:59 PM
Stewie's Avatar
Will someone please tell how to remove this thing? I accidently pushed it in while I was cleaning the surface.
Old Jun 6, 2003 | 07:30 PM
Chiovnidca's Avatar
Default Re: How do you remove head oil control orifice? (Mac8008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 &raquo;</TD></TR><TR><TD CLASS="quote">Will someone please tell how to remove this thing? I accidently pushed it in while I was cleaning the surface.</TD></TR></TABLE>
Did you try using a screw?
Old Jun 7, 2003 | 06:41 AM
Stewie's Avatar
Default Re: How do you remove head oil control orifice? (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Did you try using a screw? </TD></TR></TABLE>
Thanks for your reply! I have another question.
The head gasket procedure in the Helms says to remove it, clean it, and cahnge the o-ring. It seems like there is more of chance to do more harm than good. The orifice looks clean to me.
So my question is, do you think it would be all right if I just left it in there with out changeing the o-ring? What are the potential effects?
BTW, to remove it, do you put a srew in the small hole towards the bottom of the orifice?
thanks
Old Jun 7, 2003 | 09:35 AM
IN VTEC's Avatar
I think it's like a M6x1.00 bolt that you thread into the orifice and then you can pull it out.
I can't remember the exact size....M6 or M8.
Old Jun 7, 2003 | 12:56 PM
crazychickenhead's Avatar
they accept the 10mm headed bolts that you'll find all over your car... screw in a few threads, pull out. its that simple.
Old Jun 7, 2003 | 05:46 PM
IN VTEC's Avatar
Default Re: (crazychickenhead)
Kinda like I use a distributor bolt for a rotor removal tool.
Old Jun 26, 2009 | 11:35 AM
matttegra's Avatar
will a rivet work?
Old Jul 3, 2009 | 07:49 PM
EnjoyTheRideDC2's Avatar
Originally Posted by matttegra
will a rivet work?
How hard is it to find a 10mm bolt to use?
A rivet might work, but why go through the trouble in trying?
nexgen91
Jan 25, 2007 12:30 PM
B18C Turbo
Sep 3, 2006 09:42 AM
lakerschamp2000
May 9, 2005 09:26 PM
ViperRedCRX
Jul 31, 2003 12:10 AM
sporkcrx
Jul 7, 2003 04:44 PM
