strokers and intake manifold for B16a ???
Old Mar 29, 2003 | 12:38 AM
disamis's Avatar
Default strokers and intake manifold for B16a ???
what is the possible stroker kits for B16a? can we use B16b stroker kit(http://www.inlinefour.com/spoon18lstro.html) for B16a? is there a difference between short block of B16A and B16B? at last; what are the benefits of using skunk2 intake manifold with stock cams in B16A2?
http://www.skunk2.com/engine/manifold_dyno.htm
Old Mar 29, 2003 | 04:08 PM
joe_bocc's Avatar
Default Re: strokers and intake manifold for B16a ??? (disamis)
TODA makes a good stroker kit for the B16A, but it cost $2400.00!
You could not use the B16B stroker kit for the B16A because the B16B block has a taller deck height.
Old Mar 29, 2003 | 08:13 PM
dfoxengr's Avatar
Default Re: strokers and intake manifold for B16a ??? (joe_bocc)
make ur own stroker, use an eagle crank, different heights, and IM gives better NA power...more flow
Ej896
Oct 8, 2007 06:11 PM
Yusuke
Sep 16, 2003 11:29 AM
ATS*Mark
21
Feb 9, 2003 08:12 AM
