Odometer rollback
Old Mar 28, 2003 | 11:50 PM
mixmastabob's Avatar
Default Odometer rollback
How do you do it? Because I might be getting a new cluster for my EG DX and if the tach doesn't match then I would have to roll it back right? I know it seems like a fraud kind of question but please help me out. Thanks
PS- I would search but it says that archive searching is down at the moment. Thanks
Old Mar 28, 2003 | 11:55 PM
shermanyang's Avatar
Default Re: Odometer rollback (mixmastabob)
take the number thingy from your old cluster and put it in the new one. if you roll it backwards, there's a chance you could **** it up.
Old Mar 28, 2003 | 11:56 PM
towing_god's Avatar
ok to roll back the odometer you gotta pull out the the part of the cluster with the odometer in it and then on the back there will be a meckanisim that holds the numbers there will be a lever type deal there you should try that back and you should be able to move the numbers
Old Mar 29, 2003 | 12:15 AM
RICE POLICE SIP's Avatar
Default Re: Odometer rollback (towing_god)
DAMN! i guess i should be a little more careful now when i buy cars...
Old Mar 29, 2003 | 01:26 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
PSS:
https://honda-tech.com/zerothread?id=276819
https://honda-tech.com/zerothread?id=413826&page=1
Old Mar 29, 2003 | 05:44 AM
2000CX's Avatar
Default Re: Odometer rollback (INVALID)
is swapping the actual odometer unit actually possible?
Old Mar 29, 2003 | 05:58 AM
Caveman74's Avatar
Default Re: just find the cluster for ur car (kpxchonnom)
Some cars dealers can plug into computer to check mileage!
Old Mar 29, 2003 | 06:01 AM
97civicdx's Avatar
Default Re: just find the cluster for ur car (Caveman74)
Swap your original speedo into the new cluster. Take the cluster apart, clear cover and back panel come off. Then remove the screws holding the speedo and put your oe speedo in. Voila! Oe mileage still shows.
Old Mar 29, 2003 | 06:35 AM
misledyouth's Avatar
New User
Default Re: just find the cluster for ur car (97civicdx)
you can't plug a computer into a honda and get the millage. honda comps are read only thy don't have a prompt that they can write to.
jesse
Old Mar 29, 2003 | 07:11 AM
JDM CTR EK's Avatar
Default Re: Odometer rollback (shermanyang)
Take his advice! I tried doing it once before.... and F**ked the whole thing up!! Not worth it!
Old Mar 29, 2003 | 07:20 AM
RyanEJ8's Avatar
Default Re: just find the cluster for ur car (misledyouth)
jesse
Old Mar 29, 2003 | 07:45 AM
Happyman's Avatar
Default Re: just find the cluster for ur car (RyanCivic2000)
wear gloves.
Old Mar 29, 2003 | 09:40 AM
I tried taking the cluster apart but I cant get the little reset nub to come off. Does anyone have a link to detailed directions for this... Ive seen it somewhere here before its just that the searching is down now. Does anyone have a link to it?
Old Mar 29, 2003 | 09:49 AM
sshaikh01's Avatar
Default Re: just find the cluster for ur car ()
kpxchonnom
why the hell are you postin the *** of that hb on there thread you respond
Old Mar 29, 2003 | 10:03 AM
LshatchTurbo's Avatar
New User
Default Re: just find the cluster for ur car () (sshaikh01)
When I get my EX cluster back in the day I wanted to match the mileage so I did a roll back. I dont see how you guys **** your **** up. Its basicaly take two small *** flat heads, use one to lift the lock lever than the **** will start to move with a bit of force with the other screw driver. I am not going to get into it any more than that cause some peeps might use it for shady purposes. Carfax rules
Old Mar 29, 2003 | 10:37 AM
Mr. Thunderlips's Avatar
Sweetness...
Old Mar 29, 2003 | 12:14 PM
BackSideSA's Avatar
kpxchonnom
thinkin the same exact thing
Old Mar 29, 2003 | 12:42 PM
boosted98's Avatar
Default Re: just find the cluster for ur car (HybridHackBatch)
its not an easy task if you have know idea what the hell your doining. you can really mess it up and get into some trouble if you get caught screwing with the odometer.
Tank_EM2
Honda Civic (2001 - 2005)
Dec 19, 2017 07:09 PM
kyorishin
Mar 1, 2008 07:01 PM
girliehonda
Mar 8, 2006 01:33 PM
93DXEGG
11
Jan 3, 2006 09:00 PM
