does anyone have a pin diagram of the three main dash plugs of the dash harness?
Old Mar 28, 2003 | 12:37 PM
Aaron.'s Avatar
Default does anyone have a pin diagram of the three main dash plugs of the dash harness?
i don't have a helms for an integra, so i was hoping someone could post a scan of the pin diagram for an integra dash harness. There are 3 plugs on the left side of the dash and the colors for the plugs are green, blue and gray. I need to know what the pin location is for each wire and what it does. if someone can please please post this up, it would be really appreciated. thank you!
Old Mar 28, 2003 | 01:11 PM
sackdz's Avatar
Default Re: does anyone have a pin diagram of the three main dash plugs of the dash harness? (Zensokuryoku)
The helms doesn't have full schematics or connector pinouts w/ colors Somthing in particular you're looking for?
Old Mar 28, 2003 | 01:12 PM
uNF$@#!'s Avatar
Default Re: does anyone have a pin diagram of the three main dash plugs of the dash harness? (sackdz)
yep...please let us know. Perhaps we can help
Old Mar 28, 2003 | 01:27 PM
Aaron.'s Avatar
Default Re: does anyone have a pin diagram of the three main dash plugs of the dash harness? (Soup ****)
i don't know what to call the plugs exactly, but i know that they connect to the fuse box under the drivers side of the dash. The three plugs are greenl, blue and gray and they are what everything (cluster, climate control, etc) is wired off of. i guess you could say it's the wiring that actually connects the dash to the car. i will try to upload a pic as soon as possible. but for now, i have no idea what to call these 3 plugs.
Old Mar 28, 2003 | 01:36 PM
98R-1144's Avatar
are u talking about plugs that are just dangling there attached to nothing? i think of of them (the blue one?) is for the fogs?
Old Mar 28, 2003 | 02:53 PM
Aaron.'s Avatar
Default Re: does anyone have a pin diagram of the three main dash plugs of the dash harness? (98R-1144)
ok i finally took a pic. this pic is behind the dash taken of the driver's side of the dash. the big hole is where the steering column goes.
Old Mar 28, 2003 | 03:26 PM
sackdz's Avatar
I know what plugs you are talking about... but there is no pinout for them in the helms. However if you're trying to troubleshoot a particular circuit I can look up the wire colors for you.
Old Mar 28, 2003 | 03:38 PM
Aaron.'s Avatar
well, actually, i am trying to do the integra dash into civic swap. Basically i am trying to find out if i can splice the civic harness into the integra wiring. two of the plugs are the same but i dont' knonw if the teg wires are the same as the civic. even though they may be the same color. thanks for all of your replies
gadawg31
Dec 21, 2012 08:40 AM
EGRhatch
May 26, 2007 01:33 PM
stemiched
Jul 28, 2006 07:24 PM
fixxx
Mar 21, 2005 08:13 AM
