Dash Harness Question???
can someone post the wiring diagram for an 98+ integra dash harness? i need the pin info on the three plugs on the left hand side of the dash, the ones that go to where the fuse box is.
the plugs are green, gray and blue. i really really need the pin info for each of the plugs so if you can post the color and what its connected to, i would really appreciate it. thank you!
I swapped in a ITR dash into my old hatch a long time ago and just spliced/soldered the cluster plugs and everythign else, well I just put the dash in my new 92-95 and just used everythign I had from before, well now there is a short somewhere and my taillights dont work
well I have a complete integra harness and now since I pulled my civic dash out I have a complete civic harness and I just started to re-pin the civic plugs (grey/green/black) into the integra harness and I knwo a couple of wires won't be used but I would just liek to make sure I've got everythign going to the right place, cause I've looked a a couple of archived posts and they are all the same but different, so if someone has the wiring schematics for those 3 plugs could you please let me knwo what they are, I've got a HELMS for my civic and I've got a PDF version of a HELMS for an Integra, so if someone could just point me to the right page, or just post that info up it would be very much appreciated!
-Brandon
-Brandon
maritime_ef
Oct 26, 2011 09:05 PM
TranceAddicts
Apr 26, 2011 09:04 AM
Aaron.
Mar 28, 2003 03:38 PM
