11" fastbrakes 2 piece rotor
Old Mar 28, 2003 | 11:37 AM
euclid's Avatar
Default 11" fastbrakes 2 piece rotor
i'm looking into the 11" rotors with the directional cooling vanes. is anyone using these rotors with itr calipers? are they holding up ok? if so what pads are you running? thanks
Old Mar 28, 2003 | 11:43 AM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: 11" fastbrakes 2 piece rotor (euclid)
I use them w/ Wilwood Calipers. They`ve held up well.
Old Mar 28, 2003 | 11:51 AM
euclid's Avatar
Default Re: 11" fastbrakes 2 piece rotor (vtecvoodoo)
ive read that the wilwood calipers wear rotors and pads very quickly, which is why i want to run the itr fronts on my eh2 build-up, how long have you had them?
Old Mar 28, 2003 | 11:54 AM
vtecvoodoo's Avatar
Future Texas Boy
Almost a year.
Old Mar 28, 2003 | 12:00 PM
euclid's Avatar
alright, one more question and then i feel informed...
are you still using the same rotors, pads and caliper seals that you got in the original kit a year ago, or have you replaced them? and how much longer do you expect they will hold up?
that's 2 questions...
Old Mar 28, 2003 | 12:02 PM
vtecvoodoo's Avatar
Future Texas Boy
Still using all the OG goods although I should do pads soon.
Old Mar 28, 2003 | 12:08 PM
euclid's Avatar
thanks again man, i'm 100% about the rotors now, especially for an itr caliper application... and i will even consider the wilwoods again, i read a post where someone was complaining he went through like 5 sets of rotors/pads in year with only a few auto-x events... no thanks.
i'm going to keep searching for experience about the calipers... if they ever get it fixed.
Old Mar 28, 2003 | 12:35 PM
Black R's Avatar
25 Year Member
.....I can't find any pics or specs on the fastbrakes 2-piece rotors.
How much do they weigh? Same size as stock itr rotors?
Thanks.
Old Mar 28, 2003 | 02:20 PM
euclid's Avatar
Default Re: 11" fastbrakes 2 piece rotor (Black R)
ive heard they are 2lbs lighter than the stock rotors b/c of the aluminum center hats... there are 2 sizes 11" or 11.75" and both are 1" thick i believe.
Old Mar 28, 2003 | 03:16 PM
hecklervtec's Avatar
From: Formerly WI, now back in NorCal and everywhere else
Anybody got any pics?
Old Mar 28, 2003 | 04:17 PM
Austin's Avatar
Thanks.
Per the website:
These 11" 2 piece rotors will add to the fade resistance of any of the 11" brake upgrades. Using a billet aluminum mounting hat with the steel friction surface, these rotors will not only drop about 2 lbs per wheel of unwanted weight, they will also provide better brake cooling for increased rotor life.
NOTE: Requires using the Integra TypeR/Accord Wagon calipers. A direct bolt on upgrade.
Price $395.00
Available Options and Accessories
slotted rotors +$25.00
drilled rotors +$100.00
directional vane rotors +$50.00
4doorex
22
Jan 22, 2004 06:53 AM
slimbo
Mar 6, 2003 02:19 PM
Raymund
Nov 20, 2002 11:09 PM
ZygSpeed
Oct 4, 2001 10:30 AM
IN VTEC
Aug 20, 2001 10:21 PM
