H22 or B16a in 91 civic hatch
Old Mar 28, 2003 | 11:15 AM
uriba69's Avatar
Default H22 or B16a in 91 civic hatch
i was thinking about what kind of engine i should put into my 91 civic hatch.....i was thinking about swapping a b16a into it but then i got the idea of putting in an H22 instead.....i know that is takes up a lot more space inside than the b16a and i've also heard that the extra weight of the engine is going to make the car handle worse than it should......i want to know what do i have to do to make this engine fit into my car and if swapping it in is really worth it....
Old Mar 28, 2003 | 11:18 AM
DJ_SaNdOz's Avatar
Default Re: H22 or B16a in 91 civic hatch (uriba69)
h22- w/ the right suspension there shouldn't be handling concerns from everything I've seen & you would have a quick ride then
Old Mar 28, 2003 | 12:07 PM
BLAP BLAP!!!
Guest
Posts: n/a
Default Re: H22 or B16a in 91 civic hatch (dj_sandoz)
i would go with the b16.. it is cheaper.. u will have less custom stuff needed to be done.... and with all the extra money u can use for upgrades...
Old Mar 28, 2003 | 03:52 PM
civicdragger818's Avatar
The h22 is a trash motor compaired to the b series. It is a very fast motor for a honda in its stock form though. If you dont plan on doing anything to the motor besides just putting it in the car then go h22 other wise go b16 or even lsvtec. Just my opinion.
Old Mar 28, 2003 | 04:38 PM
projecthybrid04's Avatar
B16, cheaper, more stuff you can do, lighter, and better overall!!!!
Old Mar 28, 2003 | 05:53 PM
AVXHATCH's Avatar
Default Re: H22 or B16a in 91 civic hatch (projecthybrid04)
Yo cant really upgrade the H22a??? I seen a 98 civic take out a roush stage 2 stang, he had the H22a swap on his car.
Old Mar 28, 2003 | 06:17 PM
DOHCRX's Avatar
Default Re: H22 or B16a in 91 civic hatch (B16A6rex)
an h22a in your civic would be pretty nuts and you would be able to smoke some cars.even with the b series you could..iuf you got money i would go h22a just because its a crazy swap..i didnt have the money so i did b16 which flys in my car..so if you got the $ and fabrication talents, give the h22 some
Old Mar 28, 2003 | 09:32 PM
bossman032's Avatar
Default Re: H22 or B16a in 91 civic hatch (DOHCRX)
I am going to do a b16a SIR II OBD1!!
My next project will be a OBD1 H22..
Old Mar 28, 2003 | 10:38 PM
pagong's Avatar
Default Re: H22 or B16a in 91 civic hatch (bossman032)
I know there is somebody here on HT that has a 91 Civic with the H22 in it..it was red in color and he had it up for sale. Forgot who he is though..sorry
Old Mar 30, 2003 | 07:47 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: H22 or B16a in 91 civic hatch (pagong)
b16 for street racing.....h22 for drag....i say that because the h22 doesnt have a good turn ratio when it is in our small little cars....you will be turning and your tire would be hitting part of the engine.....if you go straight....everthing would be fine....
RanCRX
Mar 11, 2013 04:01 PM
justinrl613
23
Nov 12, 2007 04:33 AM
chevelle
Apr 10, 2007 01:26 PM
civic_std
10
Dec 21, 2005 09:57 AM
TwystedSpeed04
Sep 24, 2002 06:40 PM
