cheap/ghetto all motor d16a6 questions
Old Mar 28, 2003 | 07:41 AM
Lord Quaalard's Avatar
Default cheap/ghetto all motor d16a6 questions
Is there anyone running the d16y8 intake with d16a1 pistons and a cam on a d16a6 (CRX Si) motor. I have read a little bit about this type of setup and wanted to hear some real world results.
Right now I'm running a pretty hot cam from Gude (can't remember specs) and I think that the stock intake isn't holding up to the cam's increased flow. Also, my rings are bad, so I thought that I could make the piston switch while I've got everything apart. I'm on a tight budget since I'm trying to buy a house at the moment, and I thought that this setup might be good.
I've been searching for about 1 hour with minimal results. I was wondering since I'm going junkyarding this weekend and may pick up the intake.
Thank You,
Dru
Mods in Bio
[Modified by Lord Quaalard, 10:41 AM 3/28/2003]
Old Mar 28, 2003 | 08:09 AM
Blaze45's Avatar
Brrraaaap!
Default Re: cheap/ghetto all motor d16a6 questions (Lord Quaalard)
I think that there is a compression calculator @ cspeedracing.com for SOHC or the link is somewhere around here.
Sounds like a hot set up good luck
Blaze
Old Mar 28, 2003 | 08:10 AM
DJ_SaNdOz's Avatar
Default Re: cheap/ghetto all motor d16a6 questions (Blaze45)
http://www.knology.net/~jediklc/D.htm
d series compression calculator. that is essentially the setup i am buying parts for now- i shoudl be able to give results in a month or so
Old Mar 28, 2003 | 08:16 AM
Default Re: cheap/ghetto all motor d16a6 questions (dj_sandoz)
Thanks dj_sandoz, I hope it goes well.
12.3:1, time to go to the paint store for octane booster. Still wondering if anyone else is using this setup.
[Modified by Lord Quaalard, 11:17 AM 3/28/2003]
[Modified by Lord Quaalard, 11:18 AM 3/28/2003]
muzzeemoto86
33
May 2, 2010 05:06 PM
esteen2
Feb 18, 2005 08:31 PM
graveltravel
18
Aug 24, 2004 07:50 PM
burningwrek
70
Jul 3, 2004 11:25 AM
Def
Jun 10, 2002 06:05 PM
