snap timing belt tonight please help
Old Mar 27, 2003 | 08:36 PM
JSPECEX's Avatar
Default snap timing belt tonight please help
i was just driving normal and the timing belt just snapped. how much is a new one and which one should i get. i have lsvtec
Old Mar 27, 2003 | 08:39 PM
Kamin's Avatar
Default Re: snap timing belt tonight please help (JSPECEX)
you need to inspect the enging
usually when a timing belt goes
so does the motor.
Old Mar 27, 2003 | 09:40 PM
oldskool_rex's Avatar
I love how people ask for help after the t-belt breaks, but not before (so that they would know how and when to change it).
Put a new belt on and see how it runs. You may get lucky and the motor might be fine. Worst case is usually some bent valves in the head.....
Old Mar 27, 2003 | 09:49 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: snap timing belt tonight please help (oldskool_rex)
what kind of belt were you using??
Old Mar 27, 2003 | 10:26 PM
Jackson's Avatar
If you are using a vtec water pump, use the gsr belt. If it is still the ls water pump, use the ls belt.
Old Mar 28, 2003 | 01:03 AM
built562's Avatar
Default Re: snap timing belt tonight please help (MagoDeOz)
if you were driving at the time it broke you probably got some bent valves in the head!
Old Mar 28, 2003 | 01:22 AM
NiiS's Avatar
Yank the head and look for damaged valves, they either seat or they don`t, there`s only one way to find out...
Old Mar 28, 2003 | 02:01 AM
krazyDOHC's Avatar
Default Re: snap timing belt tonight please help (sinister)
yep, like eveyone said...take off the head and check the valves....have fun
Old Mar 28, 2003 | 03:24 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: snap timing belt tonight please help (krazySOHC)
before you do that, replace the belt and check compression. you may get lucky you may not.
Old Mar 28, 2003 | 06:35 AM
Targa250R's Avatar
be professional
Default Re: snap timing belt tonight please help (Emerika)
Old Mar 28, 2003 | 07:32 AM
JSPECEX's Avatar
Default Re: snap timing belt tonight please help (Targa250R)
i was using a ls one like a dumbass, but i can't do anything about it now. i planned on ording a knew one today i was thinking a typr r one but if there are any better suggestions please help
Old Mar 28, 2003 | 07:59 AM
g_man80's Avatar
I believe it's like Jackson said, "If you are using a vtec water pump, use the gsr belt. If it is still the ls water pump, use the ls belt." If you still are using the LS water pump I think you need to use an LS belt.
lilskud13
14
Mar 26, 2009 01:28 PM
brunorahl
Jun 4, 2006 06:52 PM
bb6h22
Sep 6, 2004 05:55 PM
1hotintegra
Jun 16, 2003 03:10 PM
flat-blk-HB
Jan 5, 2003 04:56 PM
