how to adjust headlights?
yea just wondering how to adjust them cause the driver side light is pointing real high.
its a 98 coupe, do i adjust them by turning the gears behind the headlights? if so mine dont move
[Modified by sohcSUCKS, 4:48 AM 3/28/2003]
Well, it seems the archives search function is disabled...
If you look on the back of the headlight, there is a gear. That is the horizontal adjustment. Don't touch that. If you look sideways between the radiator support and headlight, you will see another adjuster closer to the outer side of the headlight. That is vertical adjustment. You have to stick a phillips head screwdriver at an ange through the radiator support to turn the gear. Just experiment and see which way you have to turn it for the correct adjustment. Here is a link to the procedure: http://www.autooptiks.com/aiming.html
[Modified by SpoonEK2, 9:31 AM 3/28/2003]
Danger69
Oct 28, 2009 02:43 PM
im a monster hehe
Apr 18, 2006 09:05 PM
