Big bar in the way, in the CRX. How to route the downpipe?
Old Mar 27, 2003 | 02:51 PM
Ri5e's Avatar
Default Big bar in the way, in the CRX. How to route the downpipe?
There is a big bar, the radiator sits on top of it. And also, it looks like the transmission is bolted to this bar. The bar is kinda in the way and leaves very little room to route a 3 inch downpipe.
How do you guys go about routing the downpipe past this bar?
Old Mar 27, 2003 | 02:53 PM
Ri5e's Avatar
Default Re: Big bar in the way, in the CRX. How to route the downpipe? (4 Stroke)
oh, it's the front cross memberbar.
Old Mar 27, 2003 | 03:00 PM
shingles's Avatar
You can beat it up, cut it up a little, or best solution: go to http://www.jimfab.com and buy their crossmember.
Old Mar 27, 2003 | 03:20 PM
Ri5e's Avatar
Default Re: Big bar in the way, in the CRX. How to route the downpipe? (shingles)
any ever try to sneak a 2.5 inch downpipe past that bar? looks hella tricky
4U2NV's Avatar
My friend went turbo on his CRX and had to run open downpipe all the time... You can fit a 3" downpipe but you'll need the Place Racing front cross member...
Old Mar 27, 2003 | 03:38 PM
CRX SiR T's Avatar
Default Re: Big bar in the way, in the CRX. How to route the downpipe? (99 B18B)
i have the place racing front x-member too. it's an ok piece, but doesnt have the adjustability of the Jimfab piece. Fits well witha 92-95 civic half-radiator (which you'll most likely need, depending on your turbo size). just b careful with a dropped car, it likes to scrape alot
Old Mar 27, 2003 | 03:40 PM
Doodoo's Avatar
I had a shop 'sneak' a 2.5" its not pretty. but it works and its possible. I would reccomend getting a cross-member upgrade.
Old Mar 27, 2003 | 03:41 PM
Ri5e's Avatar
i hate that bar... hehe. my integra didn't have that thing in the way
Old Mar 27, 2003 | 11:15 PM
ZERO COOL's Avatar
New User
what about having the piping machine crushed right where it goes between the crossmember and block/ turbo? Would that work?
Old Mar 28, 2003 | 01:16 AM
Diablo Tejano's Avatar
Default Re: Big bar in the way, in the CRX. How to route the downpipe? (ZERO COOL)
Do you mean crush the DP? Yeah, you could probably make it fit that way, but it would put a huge bottle-neck in your exhaust system. A much more viable and logical option would be to just get an aftermarket X-member.
James
Old Mar 28, 2003 | 05:01 AM
SiR Kid's Avatar
New User
Default Re: Big bar in the way, in the CRX. How to route the downpipe? (bluboy)
I had a 2.5" DP on my turbo setup. Fit past the crossmember with hasport mounts without problems.
Old Mar 28, 2003 | 05:22 AM
BROOD's Avatar
Jim Fab bars would be a good solution
90efSI
May 10, 2006 08:03 PM
Ross
45
Oct 11, 2003 04:26 PM
Geezer
Jul 7, 2003 10:15 AM
