Big bar in the way, in the CRX. How to route the downpipe?
There is a big bar, the radiator sits on top of it. And also, it looks like the transmission is bolted to this bar. The bar is kinda in the way and leaves very little room to route a 3 inch downpipe.
How do you guys go about routing the downpipe past this bar?
Re: Big bar in the way, in the CRX. How to route the downpipe? (4 Stroke)
You can beat it up, cut it up a little, or best solution: go to http://www.jimfab.com and buy their crossmember.
Re: Big bar in the way, in the CRX. How to route the downpipe? (shingles)
any ever try to sneak a 2.5 inch downpipe past that bar? looks hella tricky
My friend went turbo on his CRX and had to run open downpipe all the time... You can fit a 3" downpipe but you'll need the Place Racing front cross member...
Re: Big bar in the way, in the CRX. How to route the downpipe? (99 B18B)
I had a shop 'sneak' a 2.5" its not pretty. but it works and its possible. I would reccomend getting a cross-member upgrade.
i hate that bar... hehe. my integra didn't have that thing in the way
New User
what about having the piping machine crushed right where it goes between the crossmember and block/ turbo? Would that work?
Re: Big bar in the way, in the CRX. How to route the downpipe? (ZERO COOL)
James
New User
Re: Big bar in the way, in the CRX. How to route the downpipe? (bluboy)
I had a 2.5" DP on my turbo setup. Fit past the crossmember with hasport mounts without problems.
