How to change pedal bracket?!
Old Mar 27, 2003 | 12:17 PM
[626]95-GSR's Avatar
Default How to change pedal bracket?!
I searched for this problem, but apparently not too many have it.
A few days ago, i was driving normally.. Clutch pedal pressure is hard as usual (heavy duty clutch) all the sudden, BAM the clutch pedal rushes to the floor with no resistance..
I checked and replace the clutch cable.. not the problem.
I look under the dash and i find that one of the welds broke on the Clutch bracket. Damnit..
So my question for you guys, what should i do?
Ive been told its a hard job to do, and time isnt on my side..
The pedal is tweaked to the side, and the clutch bracket needs to be replaced. how do i do this? do i need to replace the whole pedal assembly? thanks
Old Mar 27, 2003 | 01:26 PM
TRE_'s Avatar
Default Re: How to change pedal bracket?! ([626]Rj-SiHatchy)
well you could reweld that weld that broke but in my opinion that isnt the best choice. the EXACT same thing happen to me, because of my clutch setup. i went to honda and ordered a new pedal bracket. there are between 6 and 8 bolts that hold the bracket to the firewall. some are a little hard to get to, but just keep looking. take off all the pedals and any other restrictions(cant remeber if there are any other bolts/things in the way). then you gotta fight with it a little to get it out, it takes some pulling and tweaking but it'll come out. put the new one in and replacee all the bolts and pedals. some say its easier to do if you drop the steering column, but i decided to not do this and just did it with the steering column in the way. i dont remember EXACTLY how long it took but it gets pretty cramped up there behind the dash. my friends and i traded off and each did a little here and there. honestly, if you have a couple people to help out and you dont mind climbing up there it wont take too long. i'll admit it IS a pain in the *** but its not impossible.
good luck.
Old Mar 27, 2003 | 02:21 PM
SEA Hag's Avatar
Default Re: How to change pedal bracket?! (glowing_rotors)
I honestly could not remove the pedal assembly and all of the bolts, without dropping the steering column and removing the dash.
Old Mar 27, 2003 | 10:49 PM
Default Re: How to change pedal bracket?! (SEA Hag)
I bought the whole pedal assembly from a local parts store... I started working on it earlier today.. So far ive dropped the steering column, and i loosened most of the bolts.. This is harder than i thought it would be.. what a pain in the ***. it seems as if some bolts are impossible to get to..
anyone have any more insight on this? thanks
Old Mar 27, 2003 | 11:42 PM
Vinceg99's Avatar
Well first I have removed 3 of them so far and going to be doing a 4th one soon. The first time I ripped everything apart and got at it that way (was stripping the car anyway) the second time same thing and the 3rd time I was trying to figure out how to do it with taking the least amount of stuff out as possible. First you dont have to take out the dash or drop the steering column (its much easier though to drop it) OK the other thing that I took out since it was blocking a bolt (or 2??) was the center duct thing. There is a duct for your heat that goes right down the middle all it does is push into one side and overlaps the other pull that out and it will give you plenty of room. Oh another thing that might help is to pull out the drivers seat for more room to lay down under there. I am sure there are easier ways but this way worked for me when it comes down to removing the least amount of stuff.
Old Mar 28, 2003 | 03:21 AM
brad.'s Avatar
Default Re: How to change pedal bracket?! (Vinceg99)
ah, he did that
Old Mar 28, 2003 | 02:11 PM
TRE_'s Avatar
i heard stuff like this and it made me all nervous to do it. i got really frustrated at first but then i grabbed a little light, some extensions, and wrenchs and just went at it. i did get all cramped up with that seat in there though, if i were to do it again i'd definantly take the seat out. good luck.
Old Mar 28, 2003 | 02:27 PM
Malgerus's Avatar
God, removing that assembly is such a pain in the ***. Remember, you have to take off some of the heater tubing that runs under the dash, otherwise the assembly will hit it as you try and pull it out.
Old Mar 28, 2003 | 06:12 PM
Default Re: How to change pedal bracket?! (Mr. S)
I was just about to give up, i got all 6 bolts out (pain in the ***).. and the **** still would NOT budge... I have already dropped my steering column. Im pretty sure the only thing holding it back is that damn heater tubing under the dash, because it comes off a little bit. this is turning out to be harder than i thought and im pretty sure ive removed all the neccessary bolts.
Old Mar 28, 2003 | 10:00 PM
darkracer's Avatar
i just dropped out my old auto assembly and put in my 5 speed one, waiting to drop motor to do rest of conversion. ne way, there are the 6 ( i think) nuts on the firewall, then up behind that heating pipe is the last bolt of the top connected to the dash. if you lay down in the foot well with the seat out, the bolt is directly above your head. use a 1 ft. extension and rip the air piping out of the way. i did or else u can't get the assembly out and back in. BTW IMO u have to drop the column to get the pedal assembly out, and take out the cotter pin on the gas pedal to remove it, makes it a lot easier. any other ?'s let me know. peace.
Old Mar 29, 2003 | 09:09 PM
SEA Hag's Avatar
Default Re: How to change pedal bracket?! (darkracer)
I found that if I pulled the brake booster towards the front of the car it helped give me enough room to get the assembly out.
[Modified by SEA Hag, 12:56 AM 3/30/2003]
Old Mar 29, 2003 | 09:13 PM
AbaZ's Avatar
I did one yesterday... what a *****..
the car was going to the junkyard so we didnt ******* care about the dash or anything.. ever seen a crx dash come off in 30 seconds with a tractor? lol
Jeff
SeeAreEx!
Apr 15, 2010 02:29 PM
JDM_rolex
Jun 11, 2007 07:58 PM
syntax.
Jul 14, 2006 10:03 AM
jdm206
12
Feb 21, 2006 03:22 PM
[626]95-GSR
Mar 27, 2003 10:49 PM
