Is my JRSC Prelude running to rich? Dyno attached
Old Mar 27, 2003 | 07:53 AM
Smulude's Avatar
Default Is my JRSC Prelude running to rich? Dyno attached
Here is my JRSC Prelude Dyno test with AEM CAI and Tanabe Hyper Exhaust. Is the A/F ratio too rich??? Please let me know what do you think! Thanks
http://us.f1.yahoofs.com/users/ef46d...2Bzg.AxVOdSUDT
[Modified by Smulude, 4:54 PM 3/27/2003]
[Modified by Smulude, 12:32 PM 3/27/2003]
Old Mar 27, 2003 | 07:57 AM
keebler65's Avatar
Default Re: Is my JRSC Prelude running to rich? Dyno attached (Smulude)
most forced inductions setups are recommended to run between 12-12.5. you could probably gain some power, for example, where it is below 12 by leaning it a little, that is, if you're using something that can tune based on rpm (not just the JR FMU). although overall, it doesnt look too bad. nice numbers what PSI are you running?
Old Mar 27, 2003 | 08:28 AM
Smulude's Avatar
Default Re: Is my JRSC Prelude running to rich? Dyno attached (keebler65)
I'm running 6 PSI.
So the Apexi VAFC might help,right?
Thanks Keebler65
Old Mar 27, 2003 | 08:36 AM
keebler65's Avatar
exactly, since you can tune based on RPM. just make sure you tune on the dyno/wideband again (dont just guess with the settings)
Old Mar 27, 2003 | 08:43 AM
Smulude's Avatar
Thanks. If I want to go VAFC later, should I adjust the fuel pressure regulator in order to lower the fuel pressure. By doing this, the A/F ratio should be leaner, right?
Old Mar 27, 2003 | 01:03 PM
96IntegraRS's Avatar
Ultimately, yes, the car will run "leaner" - throughout the whole RPM range, which may not be good for the car. in general, JRSC fuel setups need fuel midrange but fuel removed in the upper RPM range (IN GENERAL SUPER TUNERS) but remember that the injectors are computer controlled in the end- a VAFC will do wonders for you for the $400 you'll spend on it and a couple dyno runs.
elpiar
Jun 7, 2006 01:00 PM
lenn
Feb 17, 2005 01:26 PM
Thrillhouse
Sep 9, 2002 02:06 PM
Daemione
Jun 28, 2001 09:42 AM
