2 Piece rotor test fitting is complete....
Did the final test fitting today with the 1" thick rotor. Had to do some minor hub hole enlarging on the hat, and change the back spacing another 1.5mm, but other than that they fit great. I'll incorporte the changes into the CNC program and they'll be ready to go. If anyone wants these rotors I'll do a group buy price of $355/pair. I'll need at least 10 orders to do this. Slotted rotors are $50/pair extra.
Can you get some pictures of the rotors possibly? What is the advantage over stock and how much increas ein performance? what about life of the rotors?
Thanks for the use of your car this morning.
I forgot to get my camera for the photos this weekend, but I'll take some Monday and send to you.
These brakes will allow you to put a lot more heat into them without warping, so for racing they should last longer. They also weigh about 2 lbs less than stock for what that's worth.
I forgot to get my camera for the photos this weekend, but I'll take some Monday and send to you.These brakes will allow you to put a lot more heat into them without warping, so for racing they should last longer. They also weigh about 2 lbs less than stock for what that's worth.
These rotors are designed to be used with the stock calipers. The Spoons will fit since the rotor will fit the stockers.
These are not the floating rotors. These are the 2 piece non floating design. The rotors alone are going to be $150 each retail...
The floating rotors for the ITR are $550/pair. They come only slotted.
fastbrakes
Jul 10, 2001 05:38 PM
