What else can I do?
Guest
Posts: n/a
Which vacuum lines are OK to block off? Can anyone draw arrows pointing to what lines are ok to block off or re-direct?
As you can see below, I am blocking that line with a screw. Where can I get the REAL "blockers"?
And what do I do with this? An aftermarket intake doesnt have a place to put this like the stock one does.
I wonder if anyone is gonna help. This forum tends to ignore my requests for help. For anyone that does help, thanks in advanced!
[Modified by ophdeheezy, 12:41 AM 3/26/2003]
The line for the air boost valve that you have in the second pic might not be needed at all. JDM motors do not have an air boost valve so I wonder if you could just uninstall the whole unit. Does it have any sensors attached to it?
I'd also like to know where to pick up some "blockers".
Also, the rubber boot on your throttle cable needs slid up so it covers all of the cable.
when i installed my intake, i ended up removing that entire blue circled piece in the second picture. not just the blue circleded rubber part, but even the plastic part after that.
i ended up plugging two lines, one in the back of the IM (red circle) and one in the front (where that plastic tubing leads to). you can get vaccuum plugs at napa, autozone, etc.
essentially you should beable to block off all your vaccum lines. your car should run, but who knows how good it will run. block it off or 'T' it to another line, as long as your not throwing a code right?
Not sure, The when you get an intake mainfold rebuilt nice they usually take them out, its is one of those tricks of the trade to get a little more juice out of the motor
If anyone is interested this is probably better than just disabling the butterflies since it removes that impediment from the airstream entirely.
https://honda-tech.com/zerothread?id=349147
Though you really should buy some 1/8" vacuum stubs.
BlueShadow
Oct 26, 2005 11:40 AM
