Turbo SOHC, which turbo to go with?
Which turbo is suitable for a SOHC? A t3/t4 is a little extreme , I think. I want something that spools good and still delivers good top end. I have the GReddy kit (td04 i believe)and pull low 13's with only a 100MPH trap. I want to hit at least 105-110MPH traps and be well into the 12's, and yes.. with a SOHC
Thanks iN ADVANCE
Thanks iN ADVANCE
Will it be able to spool up quikly? I know my friend has T3/T4 turbo ad it doesn't spool for ****, but i guess a .50 trim might spool good..
https://honda-tech.com/zerothread?id=454608
Ask CAMP13200.com he will set you up with all you FI needs.
i think a t3/t4 would be a good balance of spool up and power for your application.
on another note, how much boost are you running for those 13s? are you just pushin really high boost with those internals or are they just a safety precaution and just buildup for more power in the future?
I use the T3 60 trim with a T3 .48A/R Stage 3 trim turbine. It spools quick enough (8psi@4000rpm) with my still (ugh) stock exhaust. It would spool quicker with a more suitable exhaust attached.
I'm running 12PSI, the low compression is for percaution and just part of the buildup. I didn't want to blow the motor again... And I run on MT Drags, gota love 'em
trooper0641
Aug 22, 2005 06:55 AM
