Readjusting valves
Old Mar 25, 2003 | 08:08 PM
Jowee's Avatar
Default Readjusting valves
I was wondering how tight you should tighten the lock nut whenever you adjust the valves. Do you guys just hand tighten it or use a trq wrench?
Old Mar 25, 2003 | 08:30 PM
onyx00's Avatar
Default Re: Readjusting valves (ITR 98 1162)
Hand tightened here.
Good question.
Old Mar 25, 2003 | 08:33 PM
SurferX's Avatar
Default Re: Readjusting valves (onyx00)
There is a torque spec but I don't know how you are supposed to hold the screw in place and torque the locknut with a regular torque wrench.
Old Mar 25, 2003 | 09:12 PM
Jowee's Avatar
Default Re: Readjusting valves (SurferX)
Hand tighten as much as you do your valvecover bolts or handtighten till it won't go anymore?
Old Mar 25, 2003 | 09:38 PM
Batoutahell's Avatar
If you use the Snap-On tool, you can't get a ton of torque on the bolt, just snug it down tight. The way the tool is designed, I wouldn't worry about over-tightening unless you really go overboard and lean into it.
Old Mar 25, 2003 | 10:23 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Readjusting valves (Batoutahell)
I adjust mine using a tool similar to the Snap-On tool, and then torque them to spec, I believe it's 13 lb-ft. I use an in-lbs. wrench set to 156 in-lbs. Then I re-check the clearance to make sure the screws didn't move when I torqued them.
Yes I know, I'm a nut/bolt torquing *****, but that's me being the perfectionist that I am.
Old Mar 25, 2003 | 10:27 PM
Dave-ROR's Avatar
I just impact gun them tight.
just kidding.
I use the snap on tool and just tighten them until they feel tight.
For me, a tq wrench is used on very very few things
ninjaturtleEG
Nov 23, 2011 03:18 PM
vinuneuro
Apr 15, 2007 01:51 PM
NuRon
Mar 31, 2007 09:41 PM
G2DAB18
Dec 29, 2005 12:06 PM
jonsteR
Aug 10, 2001 08:55 AM
