zc/d15b2 oil pan similar
Old Mar 25, 2003 | 07:49 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default zc/d15b2 oil pan similar
are all d series oil pans the same as the ZC?
Old Mar 26, 2003 | 05:01 AM
Guess whos bizzack
Default Re: zc/d15b2 oil pan similar (Y49CRXSIZC)
anyone?
Old Mar 26, 2003 | 05:13 AM
drjondurst's Avatar
Only thing I could tell you is I've used a d15b1 pan for a d15b2 block. I took a good look at my ZC pan compared to my a6 pan and they look exactly the same.. Im sure they're interchangable. If you already have both pans in your possesion, just try it.
EDIT: The only reason those two might be different is cuz one is a 1.5 and one is a 1.6. Just thinking..
[Modified by drjondurst, 8:15 AM 3/26/2003]
Old Mar 26, 2003 | 06:57 AM
wronghand's Avatar
Default Re: zc/d15b2 oil pan similar (drjondurst)
My understanding is the ZC is slightly different. It should have a recess for the stock 4-2-1 manifold. I think they are all pretty much interchangeable. You may run into a problem if you have the stock ZC manifold.
HTH
Old Mar 26, 2003 | 08:19 AM
DJ_SaNdOz's Avatar
Default Re: zc/d15b2 oil pan similar (wronghand)
well, all civic oil pan gaskets are teh same, I know that...........
Old Mar 26, 2003 | 09:18 AM
RuthlessEF-9's Avatar
Default Re: zc/d15b2 oil pan similar (dj_sandoz)
im sure they're all the same they're all D series bottoms
Old Mar 26, 2003 | 09:27 AM
Guess whos bizzack
Default Re: zc/d15b2 oil pan similar (D16z6turbs)
the only reason i ask is because im putting homemade turbo on my zc this week and i already have a oil pan from a 91 crx dx, i wanna get it ready for lees down time, but i wanna be sure it'll go on first
Old Mar 26, 2003 | 10:45 AM
Outsane's Avatar
ZC and d series oil pans are interchangable..
only diff as mentioned above is the ZC has more room for the 4-2-1 down pipe..
Old Mar 27, 2003 | 06:15 AM
jlicrx's Avatar
no, they are not the same - the ZC has a sump on the bottom and a built-in windage tray - they are interchangeable, but not the same
Old Mar 27, 2003 | 06:56 AM
Outsane's Avatar
Default Re: zc/d15b2 oil pan similar (jlicrx)
Do the SOHC ZC oil pans have these same nice properties.?
huntarrr
15
Nov 2, 2004 11:27 AM
SynTeg
Aug 1, 2004 06:56 PM
iplaybass
Jan 22, 2004 09:14 PM
Almostlude
Nov 20, 2003 07:08 PM
