Search down... Need pics of B series Mounts to weld etc.
Old Mar 25, 2003 | 03:20 PM
89 CRX SI's Avatar
Default Search down... Need pics of B series Mounts to weld etc.
My friend does welding for a living and he said hed do my mounts for free. so I just wanna see if it would be a bitch to weld up some. The driverside look like just cut and weld straight on. THis is for a b16 in my crx which needs to be done hella quick upon my blowing up of damn d series turbo
i dont think i need anyhitng else for swap it would help if I could search tho cause there like 4000000 million topics on this
i have b16a
harness which apparently i can use my stock one
90-91 integra axles
90-91 teg tranny
b16a ecu
intake manifold
exhaust manifold
all that shiznat
distributor
apparently like 3-4 wires for vtec oil press etc...
Old Mar 25, 2003 | 04:42 PM
LoooseGSR's Avatar
Default Re: Search down... Need pics of B series Mounts to weld etc. (89 CRX SI)
Even though he may do it for free it may cost you money down the road, thousands and thousands(well maybe not that much, but a lot of money) has been invested by the companies that manufacture mount kits because they give the engine it's perfect alignment. If your friend knows honda's really well, then go for it, maybe it'll work out, but I'd rather stick with the mount kits simply for the peace of mind. They're gueranteed so I'll be happy to pay hasport 350 for them...
Old Mar 25, 2003 | 05:40 PM
Sirex's Avatar
Default Re: Search down... Need pics of B series Mounts to weld etc. (PSUCRX)
heh blown D16A6 turbo, now welded motor mounts...
i give that b16 a few weeks before it falls apart
Old Mar 25, 2003 | 05:48 PM
Sh4d's Avatar
I speak from experience, DONT WELD YOUR MOUNTS IN THE B SERIES POSITION. Get a bolt in kit, it saves a ton of headaches down the road and is well worth the money. If you are that against buying a bolt in kit the passenger side motor mount is moved up about 3 inches and the rear mount is moved to the bolt hole position on the driver side.
Old Mar 25, 2003 | 07:30 PM
Adam F's Avatar
Default Re: Search down... Need pics of B series Mounts to weld etc. (1337 91 EF)
I agree, to much of a headache later down the road with welding. Use a mount kit.
Old Mar 25, 2003 | 08:41 PM
89 CRX SI's Avatar
Default Re: Search down... Need pics of B series Mounts to weld etc. (Proelite103)
i just got a temp d15b7 for freee.
YHa man the d16a6 apparently cant handle 350 HP for like a month of hardcore driving.
But ya ill just get a mount kit....
Old Mar 25, 2003 | 08:52 PM
1st-hybrid's Avatar
Amen guys, do it right the first time. get a mount kit and leave out the guess work .
Old Mar 25, 2003 | 09:00 PM
pokemon's Avatar
Default Re: Search down... Need pics of B series Mounts to weld etc. (1st-hybrid)
yea considering if you weld the mounts you won't be able to go back to d-series in the future if you wanted to sell your whip without the b-series motor or some ****. HAsport mounts are ******* great. I had them myself. Good luck...
Old Mar 25, 2003 | 09:08 PM
89 CRX SI's Avatar
Default Re: Search down... Need pics of B series Mounts to weld etc. (pokemon)
ya just wanna try a B for a bit but i still love my D SOHC's y0
DC2 Maggio
Nov 13, 2008 10:29 AM
ng82sam
Dec 13, 2005 07:25 AM
King-Kong
Nov 18, 2004 07:11 AM
Jonathan_ED3
20
Sep 7, 2004 08:59 PM
b20hatch
Nov 17, 2003 06:18 PM
