What kind of radiator fluid are you using?
Old Mar 25, 2003 | 07:53 AM
drjondurst's Avatar
Default What kind of radiator fluid are you using?
Cant search.. I wanna know what kind exactly people are using. Im gettin ready to buy some for my ZC.
Old Mar 25, 2003 | 07:54 AM
EP3_05's Avatar
Default Re: What kind of radiator fluid are you using? (drjondurst)
I got some 50/50 pre mix from the local autoparts place. I forget which brand but I have never had any problems with it.
drjondurst's Avatar
Default Re: What kind of radiator fluid are you using? (91civic)
I remember reading not to just buy any brand cuz some brands have something in them that cause corrosion.
Old Mar 25, 2003 | 07:58 AM
EP3_05's Avatar
Using tap water when mixing your own will cause corrosion. You will want to use distilled water when making your own mix.
Old Mar 25, 2003 | 09:57 AM
Quik89Si's Avatar
Nah, he's talking about the additives in certain anti-freezes...phosphates or something, I don't remember. *EDIT* But it is also true that tap water will eat seals and cause corrosion as well.
That's why I use Honda Type 2 - it's already mixed for you so you don't have to go and get a bunch of distilled water. However, I am debating adding a bit of distilled water to the pre-mix, since water has better heat-removing properties than the antifreeze itself.
It's not that expensive and I bought 2 gallons at my local dealer.
Alex
[Modified by Quik89Si, 10:58 AM 3/25/2003]
Old Mar 25, 2003 | 10:02 AM
madman13lm's Avatar
Default Re: What kind of radiator fluid are you using? (Quik89Si)
Im using home filtered water. We had some guy check our water and it turns out that we have less particles in our water than most distilled water. I am getting ready to replace the radiator anyway. Im thinking when I get the new one I will run water and "water weter" or whatever its called. So nice to live in florida.
Old Mar 25, 2003 | 10:12 AM
Mr Furball's Avatar
Thats why I bought Water Wetter
Old Mar 25, 2003 | 10:54 AM
Quik89Si's Avatar
Default Re: What kind of radiator fluid are you using? (FURBALL B-16)
Yeah, I was thinking the same thing...maybe a bit of both! I know for sure I won't be in danger of my engine freezing over.
Alex
Old Mar 25, 2003 | 10:57 AM
RCautoworks's Avatar
So if we don't buy 50/50 mix, where should we get the water from ? I used tap water before and now I'm worried. My new engine only has about 8,000 miles. And I was plaining on flushing the system soon, you think corrison already started ?
Old Mar 25, 2003 | 11:03 AM
Ef Whore's Avatar
Default Re: What kind of radiator fluid are you using? (90blackcrx)
Chill out, no reason to **** a brick over tap water----The best thing for the system is Prestone 50/50(demineralized already), and 3/4 of a bottle of water wetter. That is for a street car anyways. With this combo my fans never come on even after beating the **** out of it. The needle is also significantly angled more towards the"cold" mark. Dont forget to bleed!
Old Mar 25, 2003 | 05:39 PM
Quik89Si's Avatar
Yeah don't trip over the tap water...but next time, if you mix the stuff yourself, all you gotta do is go to the store...Grocery store or whereever...and get a couple bottles of the distilled stuff. That's it.
Alex
Old Mar 25, 2003 | 07:20 PM
Adam F's Avatar
water wetter works great
Old Mar 25, 2003 | 07:42 PM
matt j's Avatar
Default Re: What kind of radiator fluid are you using? (Proelite103)
im running dex cool!
Old Mar 25, 2003 | 08:20 PM
StorminMatt's Avatar
Default Re: What kind of radiator fluid are you using? (mattED6)
I'm running a 50/50 mix of Dexcool and distilled water. I should also note that when buying water, 'purified water' is basically the same thing as distilled water.
Old Mar 25, 2003 | 08:26 PM
Urban Business
Guest
Posts: n/a
i do 100% of the **** from the gas station. works like a champ doesnt gel, doesnt over heat. cheaper the better.
Old Mar 25, 2003 | 08:33 PM
.bagged's Avatar
Default Re: What kind of radiator fluid are you using? (limoZeen)
I use the green ****
is it true that there are only three plants in the US that produce anti-freeze, thus making buying brand names really just buying the name?
Old Mar 25, 2003 | 08:40 PM
Rywire's Avatar
Default Re: What kind of radiator fluid are you using? (bagged93accord)
I only use genuine honda. Ryan
Old Mar 25, 2003 | 09:22 PM
drjondurst's Avatar
Default Re: What kind of radiator fluid are you using? (droppedcrxsi)
I think Im gonna do that. I'll probably get it when I go to the dealer to get some tranny fluid. How much is it gonna cost me?
Old Mar 25, 2003 | 09:31 PM
shortyz's Avatar
i take my hose. fill it half, then fill the other half with 3.99 antifreeze/coolant..
Old Mar 25, 2003 | 10:33 PM
Vinceg99's Avatar
Default Re: What kind of radiator fluid are you using? (shortyz)
I see all these people using the 50/50 premix stuff and the thing you dont realize is that when you flush your system your not getting all of the water out so if you put in 50/50 its not going to be 50/50 anymore since there is quite a bit of water left in your system. If your going to use the 50/50 I would make sure that you have a test kit on hand to test it after your done oh and it may be a good idea to have a bottle of straight up antifreeze so that if its not to where you want it you can add in more antifreeze.
Old Mar 26, 2003 | 08:34 PM
Rywire's Avatar
I think its around 15 bucks. I have forgotten. Its worth it in my opinion. Ryan
Old Mar 27, 2003 | 08:23 AM
martini's Avatar
Default Re: What kind of radiator fluid are you using? (Vinceg99)
It doesn't matter if it's not EXACTLY 50/50. I nfact, I would suggest that for performance, you use more like a 40/60 or 30/70 water to antifreeze.
But the guy that fills up his **** with a hose is a fool. Take better care of your car.
Old Mar 27, 2003 | 09:33 AM
Vinceg99's Avatar
Default Re: What kind of radiator fluid are you using? (martini)
OK you make no sense at all you say that it doesnt matter if it isnt exactly 50/50 which is true but what I am saying is that if you get 50/50 and add that to a system that already has water in it you will be diluting the system even more and here you go and post
OK how do you get 40/60 or 30/70 water to antifreeze if you add 50/50 to a system with water in it?? Yeah you would get those numbers but hello it would be 40/60 or 30/70 <U>ANTIFREEZE TO WATER!! </U> Cause there would be not a chance in hell that you could add predeluted antifeeze to water and then get a mixture that would be higher in antifreeze
Oh and here are a fews numbers to through at you a 91 CRX Si holds 5.8 quarts of coolant so if you have a system with water in it (as much run out as possible) you still wouldnt be adding much antifreeze to it considering how much would still be in the block or in the heater core. A 50/50 mixture gives you -34deg. F freeze protection and a +265deg. F boilover with say a 70/30 (more antifreeze than water) that jumps up to (or down to) -84deg F freeze protection and up to +276 boilover protection.
Old Mar 27, 2003 | 10:34 AM
Quik89Si's Avatar
Okay, someone explain this to me. I know that antifreeze is called antifreeze because it freezes at a lower temperature than water does.
However, doesn't antifreeze boil before water? So wouldn't having a mix with more water than antifreeze (like 60% water, 40% antifreeze) evacuate more heat out of the system and therefore make your car run cooler? And be better for performance?
Obviously if you run like the 60% water/40% a-f mix your car could freeze over easier *IF* temps get that low in your area.
Please set me straight on this, guys. I was thinking about adding some distilled water to my 50/50 premix from Honda to make the car run a bit cooler.
*EDIT* according to the post above, the boiling point of antifreeze seems to be way higher than that of water. Doesn't water boil at 212? Been a long time since I had a science class.
Alex
[Modified by Quik89Si, 11:36 AM 3/27/2003]
Pellegrini808
Jul 9, 2015 07:03 PM
G2_Fella
Jun 26, 2008 08:29 PM
lude98SH
Sep 30, 2005 12:26 PM
onyx00
Jun 12, 2002 06:01 PM
94vteclude
May 18, 2001 01:58 PM
