Is my Oil return line too close to my DP???
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Like the topic says..
Here are the pics, let me konw if you guys think it is too close or not.
yeah yeah, I see that my DP is burning oil. Don't need to point it out to me.
Good to know.... I will get some heat wrap for it soon. Can't be sure enough for it!
Thanks for the help.
If anybody else has comments, they are welcomed.
I don't suppose you have a pic so I can get a better idea. I mean, yeah, it's not that hard to figure it out, but.. pictures are worth a thousand words.
Does yours leak too?
Cuase if yours dont' leak, then I'm envious!
wow you got plenty of clearance. On my first ss line, it was touching, at killed the line.
Now my line is maybe half a centimeter away and so far no problems.
It's good to know that the majority seems to feel that it has enough clearence, here I thought that it was too close and maybe the rubber hose inside the SS line might have cooked and oil was leaking becuase of that.
But.. apparently, it's... something else...
hoorah.
... Do local car shops (autozone) have good heat wrap? Or is it something I should order??? Suggestions?
hoorah.
I'm using a rubber line and it's only about half and inch from the downpipe... But heatwrap works wonders.... no leaks yet(knock on wood). Napa here didn't have heat wrap, but I'm sure some shops there would have it.
Nate
Nate
mines right on my dp and its not burnt thru yet, but is like perspiring oil thru the line. not alot, but enough to make me fix it one day
What is a sign of your SS line leaking? Will it show burnt dark marks? Or will there be a.. physical sign of the line showing wear?
I'd like to know so I can see for myself.
whats that part in silver wrap? Is this your wg dp?
mine is closer than that..
this was my rubber return line
this line was alot closer than yours though... from the looks of yours you should be fine
BlueShadow
Dec 18, 2005 10:06 AM
FOrSfEd
Feb 1, 2004 04:33 PM
